What's the best way to make random look "not random?"
Sun Jan 04, 2015 4:34 pm
mattyf offline
So I want to create a schedule where one light turns on, then stays on for say 45 minutes plus or minus 15 minutes. A few minutes before that light turns off, a second light (which light would change each time the schedule was run) would turn on. The two lights would be on together for a bit, then the first would turn off. And so forth throughout the evening.
The only way I can really figure to do this is to create a bunch of these sequences manually, say like ten of them, and then choose one of those ten at random each day.
Is there an easier way to do this? And is there a way in Indigo to generate a random number between two set numbers (like to specify a random number from 1 to 20)?
Sun Jan 04, 2015 4:43 pm
Re: What's the best way to make random look "not random?"
For the random number part of your question.
In Python:
import random
x = random.randint(1,20)
In Applescript, see this post:
viewtopic.php?f=5&t=10643
Dave
Sun Jan 04, 2015 8:54 pm
achterberg offline
This doesn't address the request for turning a light on before another light turns on, but this external python script is called in an action when the house is set to sleep. By adding a key phrase, in my case "random" in the description field of the device, a list of those devices is generated and looped over turning them on and off, having a random delay time between the lights and a random duration time the lights are on. If the house becomes occupied or it is after sunrise after any of the delays, the script will exit. The idea is from an applescript I got from an old post years ago and I updated it to python. I'm sure there may be coding issues that could be done better, if anyone sees anything to improve suggestions are welcome.
#!/usr/bin/env python2.5
# -*- coding: utf-8 -*-
import indigoAttachments
import random
import sys
import datetime
import time
housemode = indigo.variables[1563423774] # HouseMode
isDaylight = indigo.variables[351661523] # isDaylight
iterCount = 6
# Build a device list for all devices that have the word "random" in their description
dev_list = [dev for dev in indigo.devices.iter() if "random" in dev.description]
random.shuffle(dev_list)
while iterCount > 0:
   for dev in dev_list:
      if indigo.variables[1563423774].value != "occupied":
         randomDelay = random.randint(600, 1800)
         indigo.activePlugin.sleep(randomDelay)
         if indigo.variables[351661523].value == "true" or indigo.variables[1563423774].value == "occupied": sys.exit()
         indigo.device.turnOn(dev)
         randomDuration = random.randint(600, 3600)
         indigo.activePlugin.sleep(randomDuration)
         indigo.device.turnOff(dev)
         iterCount -= 1
         if iterCount == 0 : indigo.server.log("Random Light On script completed", "Random Light On")
Mon Jan 05, 2015 5:12 pm
akimball offline
Here was my final solution for "VacationMode" using 8 of these scripts to control 8 individual lights separately, but randomly for each instance. I didn't worry about overlapping lights... I walk through my home in the dark all the time. I did make sure I selected just certain lights however visible from outside. When I'm away I simply set a variable "vacationMode" to 'true' and my mac does the rest.
viewtopic.php?f=4&t=11480
-Al
Sat Jan 17, 2015 2:19 pm
richo offline
here is my version of a script based on my old script I have used in LUA in HC2 and your suggestions.
It uses a bit different concept - devices are toggled randomly and I use variable "random_lights" to turn it on/off also with a trigger.
It allows me for more flexibility and looks more natural as not all the lights are turned off at the same time. It's also quite simple in my opinion.
Please use it and comment if you think it makes sense.
from random import randint
devlist = [dev for dev in indigo.devices.iter() if "random" in dev.description]
nrdev=len(devlist) #nr of devices in a list with "random" in description
# indigo.variables[701673380] # "random_lights" if false then stop running
# indigo.variables[967444605] # "isDaylight"
while indigo.variables[967444605].value == "false" and indigo.variables[701673380].value == "true":
   rndindx=randint(1, nrdev)
   dev = indigo.devices[devlist[rndindx-1]]
   indigo.device.toggle(dev)
   indigo.server.log("Toggling %s" %(dev.name),"Random lights")
   rndSleep = randint(900, 1800) #random sleep before next round
   indigo.activePlugin.sleep(rndSleep)
   indigo.server.log("Sleeping for %s seconds" %(rndSleep),"Random lights")
indigo.server.log("Script has finished", "Random lights")
for dev in devlist:
   indigo.device.turnOff(dev) #turn off all devices
Ryszard
