So I want to create a schedule where one light turns on, then stays on for say 45 minutes plus or minus 15 minutes. A few minutes before that light turns off, a second light (which light would change each time the schedule was run) would turn on. The two lights would be on together for a bit, then the first would turn off. And so forth throughout the evening.
The only way I can really figure to do this is to create a bunch of these sequences manually, say like ten of them, and then choose one of those ten at random each day.
Is there an easier way to do this? And is there a way in Indigo to generate a random number between two set numbers (like to specify a random number from 1 to 20)?
