[SOLVED]Scheduled Events and Motion Sensors
Tue Dec 17, 2013 8:09 pm
rob_hut offline
So I cant wrap my head around how to do this, so perhaps someone can help with the logic. I want a variable to go from false to true if motion has not been detected for at least an hour and it is past a time, say 11pm.
So here it is in a sentence, "If it is past 11, but before 8 am and motion has not been sensed in the last hour, then check every 5 minutes afterward, as soon as there has been no motion for an hour, set the variable from false to true"
I am getting heartbeats from the motion sensors...
Any ideas?
Tue Dec 17, 2013 11:08 pm
Re: Scheduled Events and Motion Sensors
you could use "timers and pesters" start one at 11 and every time you get a signal (trigger on change) then cancel and restart timer .. once timer is expired (i.e. no signal after one hour) do your action.
pesters.tiff
pesters.tiff (61.32 KiB) Viewed 2464 times
Wed Dec 18, 2013 8:59 am
rob_hut offline
that is a plugin?
Wed Dec 18, 2013 9:09 am
evansgo offline
Its built into Indigo 6 plugins, what version are you using?
Wed Dec 18, 2013 11:13 am
rob_hut offline
6! Ill check and enable it when I get a chance, thanks!
