Triggered Environmental Report
Mon Jun 13, 2022 3:39 pm
Hap offline
I have a multitude of sensors around the house and use variables to set tolerance limits. I also have periodic reports (twice) a day go out just so I can see status.
If my EnvironmentalAlert is flipped to TRUE based on limits I've set, then reports go out every 15 minutes until either I disable Alerts, or the values come back into tolerance. The question I have is there an easy way to send JUST the items that are out of tolerance without creating a trigger/report for each and every one of them?
This is what a standard (i.e. periodic) report looks like (and no, that's not all my sensors):
Weathercat:
Internal Temp: 71.0F
Internal Humidity: 61
External Temp: 93.4F
External Humidity: 64
Heat Index: 111.7F
Daily Rain: 0.00 in
Windspeed: 5 mph
Ecobee:
Main Temp: 73.2F
Master Bedroom Temp: 72.0F
Craft Room Temp: 73.9F
Living Room Temp: 73.2F
Z-Wave:
Becky's Garage: 82.0F \ 67.0%
Craft Room: 74.1F \ 51.0%
Master Bedroom: 73.1F \ 51.0%
Office Closet: 77.8F \ 54.0%
Office: 68.8F \ 67.0%
Safe: 81.4F \ 62.0%
Shelter: 74.5F \ 72.0%
Wiring Closet Temp: 71.9F \ 77.0%
Workshop: 72.4F \ 48.0%
Woodshop: 71.7F \ 72.0%
However it would be nice if when an item or two went over a limit, I could just get the items that are over/under the limits. This goes out over Pushover as well, and I'm character limited there and would like the ability to know what's out of limits specifically. The pushover template is smaller (I cut out the external and none critical items), but still too large.
Attached is the trigger (and I want to add to it, specifically a couple of more temps and Safe Humidity) which is easy enough. Just want a more focused report WHEN something is out of limits. Thoughts?
Also, would be great if the "Is between" condition supported variables like the "is greater than" and "is less than" do.
Screen Shot 2022-06-13 at 4.28.44 PM.png (133.72 KiB) Viewed 1330 times
Mon Jun 13, 2022 4:38 pm
Re: Triggered Environmental Report
Time to learn Python.
