Trigger not firing since indigo 2022.1 based on variable
Sun May 22, 2022 12:56 pm
Butch2427 offline
I have an alert trigger that notifies me when our greenhouse temperature reaches a set point. The setpoint is a variable (id# 586566111) which goes up or down based on a control page button.
Since my upgrade to indigo 2022.1 (OS Monterey 12.3.1) the trigger will no longer fire. If I use a static number such as 80 instead of %%v:586566111%% the trigger will fire.
Thoughts?
Butch
Sun May 22, 2022 3:21 pm
Re: Trigger not firing since indigo 2022.1 based on variable
Post a screenshot of the trigger definition dialog.
Sun May 22, 2022 5:51 pm
Butch2427 offline
here ya go...
Also.... if I try to use the "execute conditional actions" button the trigger will not fire. The "Execute actions only" does fire.
Screen Shot 2022-05-22 at 4.47.34 PM.png (38.99 KiB) Viewed 1264 times
Screen Shot 2022-05-22 at 4.47.14 PM.png (50.36 KiB) Viewed 1264 times
Screen Shot 2022-05-22 at 4.46.54 PM.png (40.73 KiB) Viewed 1264 times
Sun May 22, 2022 7:01 pm
That trigger has never worked - substitutions don't work in the built-in trigger dialogs.
You could do a "has any change" trigger then write a conditional script that would check both your current condition and do the comparison to the variable value.
