Trigger (KeyPad) not initiating Action Group
Wed Mar 04, 2020 11:52 am
ryandenver offline
Greetings
I've setup an Action Group for a room lighting scene to be used by various Insteon Keypads in my home. Sometimes it works immediately. Sometimes it takes a few on/off cycles to get any or all of the lights to respond. Is there something I'm missing to make the trigger/action group/scene combo work reliably?
Wed Mar 04, 2020 12:09 pm
Re: Trigger (KeyPad) not initiating Action Group
Are you seeing errors in the Event Log window when it doesn't fully work? Copy/paste what you're seeing.
Wed Mar 04, 2020 7:59 pm
ryandenver offline
I'm not seeing any errors and it's happening with two triggers/action groups/scenes that I've setup to test with.
Creation Steps:
1) Created Action Group
2) Created Scene within Action Group
3) Created Trigger for ON and a Trigger for Off linking to an Insteon Action Group & Scene
Screen Shot 2020-03-04 at 6.51.47 PM.jpg (33.12 KiB) Viewed 1877 times
Thu Mar 05, 2020 9:21 am
And after Indigo sent the Insteon Scene command in your screen capture, some devices in that scene didn't turn on and you didn't seen any Insteon no ack errors?
Thu Mar 05, 2020 10:01 am
ryandenver offline
That's correct, lights didn't go on (or off in some cases when turning the scene off) and no errors were presented. Similarly configured 'scenes' using devices linked directly to the button rather before converting the scene to an action group had no issues.
Thu Mar 05, 2020 11:26 am
Select the Interfaces->INSTEON/X10 Power Line->Configure... menu item. On the resulting dialog, click the Interface Options... button. On the resulting options dialog, check both checkboxes at the top of that dialog and try again (watch for more errors in the Event Log window).
Sun Mar 08, 2020 2:43 pm
ryandenver offline
That worked. It's introduced a slight delay between DIN modules activating, but it is working.
Thank you
