iOS Shortcuts?
Fri Sep 27, 2019 8:32 am
citysnaps offline
iOS Shortcuts?
I just learned about iOS shortcuts. And that the latest iOS update supports geographic iPhone location.
Since my iPhone is always with me, I'd like to create a shortcut that would generate Indigo triggers whenever I leave the house and automatically perform certain actions; ie enable my cameras, handle lights, etc. And the n when I return, perform other actions; disable cameras, turn on certain lights, etc.
Is there a way to set an Indigo variable based upon an iOS Shortcut action via a plugin? I searched and couldn't find one.
Brad
Urban photoblog: www.citysnaps.net
Fri Sep 27, 2019 8:50 am
Re: iOS Shortcuts?
I used shortcuts to execute an ssh command works well.
There should be a command that does an html call.
Go into shortcuts and do a search
I have not found a list of short cut commands in the web. Only in shortcuts you can find then
Fri Sep 27, 2019 1:05 pm
Re: iOS Shortcuts?
played around a little:
this works:
put this into the script filed of an ssh short cut on your iphone
/usr/bin/curl -u xxx:xxx --digest -X PUT -d value="abc" http://127.0.0.1:8176/variables/testd
where xxx:xxx is userid:password of your indigo server
and "abc" is the string you like to send to variable "testd"
and the "User" and "Password" in the ssh fields are the server login uid/pwd
Screen Shot 2019-09-27 at 15.12.56.png (105.17 KiB) Viewed 4562 times
Fri Sep 27, 2019 4:07 pm
Re: iOS Shortcuts?
and this should trigger an action:
/usr/bin/curl -u xxx:xxx --digest -X  EXECUTE http://127.0.0.1:8176/actions/name%20of%20Action
with >>name%20of%20Action< = "name of Action"
see: https://wiki.indigodomo.com/doku.php?id=indigo_s_restful_urls for more examples
using ssh has the advantage that with opening port22 to your indigo server and a getting a dns name for your router
you then can do the ssh from anywhere in the world. And ssh is pretty secure.
instead of 192.168.1.x you put eg "thisIsmydnsName.net" into the ssh Hostname field
Fri Sep 27, 2019 4:24 pm
Re: iOS Shortcuts?
or you could check if you are connected to you home network and if not =="yours" send message or do the ssh --> curl --> indigo server thing to tell indigo that your phone is not at home:
Screen Shot 2019-09-27 at 17.22.47.png (54.39 KiB) Viewed 4542 times
Fri Sep 27, 2019 4:26 pm
Re: iOS Shortcuts?
the only bad thing about short cuts in iOS is that you have to enter / set / configure everything on your phone.. no editing on your mac
getting the hang of it ..
Fri Sep 27, 2019 4:38 pm
citysnaps offline
Re: iOS Shortcuts?
Thanks Karl - appreciate it!
When I get home later on I'll try getting the above to work.
Brad
Fri Sep 27, 2019 5:45 pm
Re: iOS Shortcuts?
w iOS 13.1 short cuts
==> you can now do an "arrive at location automation" :
in shortcuts
- select automation (not my shortcuts)
- add create "personal automation" item,
- choose arrive at .. set location,
- and add the ssh action described above
then the indigo action will execute when the iphone gets into the perimeter ring around your location.
that is really cool
Screen Shot 2019-09-27 at 18.42.26.png (83.39 KiB) Viewed 4509 times
Fri Sep 27, 2019 6:47 pm
Re: iOS Shortcuts?
Just tried this returning from shopping
..and it works.
Fri Sep 27, 2019 7:51 pm
Re: iOS Shortcuts?
But :::: For automated actions like arrival: you need to click on ok when it runs.
That kills it from my perspective.
Starting shortcuts manually though works fine.
Fri Sep 27, 2019 8:55 pm
citysnaps offline
Re: iOS Shortcuts?
I've been playing around with iOS automations (Arrival -> Speak some text) and discovered the same thing. Poking around trying to find out why I need to RUN the automation I found this Apple document that confirmed: https://support.apple.com/guide/shortcuts/enable-or-disable-a-personal-automation-apd602971e63/3.1/ios/13.1
That's such a disappointment. If I need to tap RUN when I arrive home, I might as well access my Indigo Touch control page on my phone and turn on the lights.
Hope Apple reconsiders having to manually run an arrival automation.
Brad
Fri Sep 27, 2019 9:41 pm
Re: iOS Shortcuts?
the advantage compared to the indigo app is : it pops up = 1 "ok" click ,
-- or you do siri: say "hey siri home" and the action happens
vs
Indigo app: you need to open the app, go through menus, then click on action button = 3 + steps
still not as I like to see it .
Sat Sep 28, 2019 1:26 am
Londonmark offline
Re: iOS Shortcuts?
Have you tried linking to HomeKit? I’ve previously had some success with triggering HomeKit devices through the Home App on arrival and departure.
Sat Sep 28, 2019 6:29 am
jlambert121 offline
Re: iOS Shortcuts?
It would be great if indigo touch had app shortcuts available as well vs ssh that would use the reflector if needed. Even basic variable manipulation would let you take action on the server based on the variable change.
Sat Sep 28, 2019 6:36 am
Londonmark offline
Re: iOS Shortcuts?
To expand on previous post, you can create automation in the home app to switch on homekit appliances on arrival home (way). I don’t think that requires you to unlock your phone. And if you have an indigo action instead of a HomeKit device set up in HomeKit bridge you can make all sorta of things happen.
