Trigger not consistently working
Fri Nov 17, 2017 10:05 pm
P15-D24 offline
Keypadlinc controller InlineLincs for the functions (light, fan, heat, nite light), trigger set to change LED status (turn off button LEDs) when the off button is pressed.
New installation, all new equipment.
Sometimes it works fine but lately I've getting the following errors:
Received INSTEON "Cottage Bathroom Keypad Switch" on (button 6)
Received INSTEON "Cottage Bathroom Keypad Switch" off (button 1)
Trigger Cottage Bathroom Button Off
Sent INSTEON "Cottage Bathroom Keypad Switch" raw insteon command (2E 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00; ack: 00)
Sent INSTEON "Cottage Bathroom Keypad Switch" raw insteon command (2E 00 00 09 C2 00 00 00 00 00 00 00 00 00 00 00; ack: 00)
Received INSTEON "Cottage Bathroom Keypad Switch" off (button 3)
Received INSTEON "Cottage Bathroom Keypad Switch" on (button 3)
Received INSTEON "Cottage Bathroom Keypad Switch" on (button 4)
Received INSTEON "Cottage Bathroom Keypad Switch" off (button 6)
Received INSTEON "Cottage Bathroom Keypad Switch" start dim (button 1)
Received INSTEON "Cottage Bathroom Keypad Switch" stop dim (button 1)
Received INSTEON "Cottage Bathroom Keypad Switch" off (button 4)
Received INSTEON "Cottage Bathroom Keypad Switch" on (button 5)
Received INSTEON "Cottage Bathroom Keypad Switch" off (button 5)
Received INSTEON "Cottage Bathroom Keypad Switch" off (instant) (button 1)
Received INSTEON "Cottage Bathroom Keypad Switch" on (button 1)
Error "Cottage Bathroom Keypad Switch" raw insteon command; send failed (no acknowledgment)
Sent INSTEON "Family Room Controller" keypad button 6 on
Sent INSTEON "Family Room Controller" keypad button 6 off
Nov 17, 2017, 7:51:08 PM
INSTEON Commands Error Failed to get current LED states for device 1746194541 - aborting
Nov 17, 2017, 7:53:29 PM
Running OS X 12.2.1 on 2018 Mac Mini, Indigo 2022.2
http://www.p15-d24.com
Sat Nov 18, 2017 1:57 pm
Re: Trigger not consistently working
You've got a traffic/collision problem (I'm assuming that all that traffic is happing at roughly the same time). It looks like "Cottage Bathroom Keypad Switch" is having some kind of issue given all the repetitive messages. It could be that the switch is failing or it could be that some other kind of noise is making it retry excessively.
