I'm looking for an elegant way to turn on my gas burner when one of my radiator valves is opened. (and vice versa, turn off the gas burner when all valves are closed).
So, I have 5 radiator valves that are controlled through Indigo, they are all virtual devices that engage relays.
I also have 5 corresponding variables, to tell me if the valve is open or closed.
If I create a trigger, I can only choose one event, but ideally, I would like to monitor all 5 variables, and if one valve opens, turn on my gas burner (I think you call it boiler, but that's something different here in Belgium
I have looked at device groups, but these do not work with virtual devices, only actual devices (if I'm not mistaken).
I could do it in a schedule that runs every few minutes, but I'd like to know if there is a more elegant solution, maybe a plugin ?
