Handling Holidays
Mon Sep 04, 2017 7:37 am
Different Computers offline
Handling Holidays
Who has a clever way of handling holidays like today--ones that aren't on a certain date every year. While my dog will only let me sleep so late regardless, I could get another 30 minutes in if my "People are up now so I'm changing the house mode" trigger knew to ignore someone moving around at 7 am on a holiday.
Ways I want to avoid using:
pressing a "Tomorrow is a holiday" button.
manually adding a bunch of date conditions to triggers, unless any trigger working that way is referring to some script magic.
Mon Sep 04, 2017 8:44 am
Re: Handling Holidays
Run this script every night just after midnight. I created the two variables in advance. Creating them at run time is an exercise for the student. ;)
# indigo.variables[1980497029] # "isHoliday"
# indigo.variables[1479852422] # "whatHoliday"
from datetime import date
import holidays
indigo.variable.updateValue(1980497029, value="False")
us_holidays = holidays.UnitedStates()  # or holidays.US()
if date.today() in us_holidays:
   indigo.variable.updateValue(1980497029, value="True")
   indigo.variable.updateValue(1479852422, us_holidays.get(date.today()))
Mon Sep 04, 2017 9:25 am
I don't think holidays is a standard python module is it? You'll probably have to install it first.
Mon Sep 04, 2017 9:28 am
Could be. It's been a while since I wrote that.
Mon Sep 04, 2017 11:34 am
racarter offline
If you don't want to install the holidays module you could make a variable called 'Holiday' or whatever you'd like to call it, then run this script once per day:
import urllib2
import requests
import simplejson as json
from datetime import datetime
bhVar = indigo.variables[77648381]  #Change this to your Holiday variable ID
thisDay = datetime.today().strftime('%Y-%m-%d')
url = 'http://www.webcal.fi/cal.php?id=435&format=json&start_year=current_year&end_year=current_year&tz=Europe%2FLondon'
resp = requests.get(url=url)
data = json.loads(resp.text)
holDesc = ""
for i in data:
    if i['date'] == thisDay:
        holDesc = i['name']
        break
indigo.variable.updateValue(bhVar, holDesc)
The url shown is for UK but a visit to http://www.webcal.fi/en-GB/other_file_formats.php will enable you to create a url for anywhere in the world. (Be sure to select the json option.) If today is a holiday the variable will be set to its name, otherwise it will be left an empty string. A trigger could be created to do something when the variable is not empty.
Mon Sep 04, 2017 12:36 pm
[SNIP]
Excellent! I always like solutions that don't require installing Python modules. I found that website somewhat confusing, so to help avoid that here are the steps I took (if they don't redesign the website):
  1. Click on Other file formats in the navigation menu to the left
  2. Select Holidays from the Calendar popup (or adjust as necessary depending on what you want)
  3. Select JSON - JavaScript Object Notation from the File format popup
  4. Select your timezone from the Time zone popup
  5. Click the Show download URL button
  6. Copy the URL shown in red and paste it into the script in place of the url variable in the script (2nd line of my script below)
I simplified the script somewhat - both things that need customization are at the top of the script:
#### Replace this URL with the one you got from the website above and replace the variable ID with the ID of your variable
url='http://www.webcal.fi/cal.php?id=52&format=json&start_year=current_year&end_year=current_year&tz=America%2FChicago'
variable_id=REPLACE_WITH_VARIABLE_ID
import requests
resp = requests.get(url)
data = resp.json()
holDesc = ""
for i in data:
    if i['date'] == str(date.today()):
        holDesc = i['name']
        break
indigo.variable.updateValue(variable_id, value=holDesc)
I love this, thanks @racarter!
Mon Sep 04, 2017 1:00 pm
Very cool stuff! Gotta be careful though: Lots of people don't get things like Columbus Day off. Maybe there's a way to make it look at a custom web calendar URL.
Also shame on me for asking such a question on Labor Day, when Jay should be relaxing!
Mon Sep 04, 2017 1:13 pm
racarter offline
You could always modify the script to ignore specific holidays you don't want flagging...
Wed Jun 13, 2018 1:42 pm
noel1983 offline
Just getting around to implementing this.
Ideally I want to run this in the evening, before bedtime to check if its a bank holiday the following day. Is it easy to amend it for 'tomorrow'?
Noel
Wed Jun 13, 2018 2:13 pm
Change:
to:
    if i['date'] == str(date.today() + timedelta(days=1)):
and
to:
from datetime import date, timedelta
Should do it. Not tested at all....
Wed Jun 13, 2018 2:14 pm
noel1983 offline
Awesome thank you!
