Motion Triggers Enable/Disable
Tue Aug 29, 2017 3:48 pm
qcvictor offline
I use my device motion sensor from dsc plugin for "Light On" with a trigger when motion is detected and another trigger "Light Off" where I set the duration based when "Light On" come true.
I would like Override these triggers when I push manually the switch or double tap and go back when I turn off the switch .....
I read wiki about motion but the sensor from dsc plugin don't work as insteon motion,
Someone for help me with the best practice for this case ?
Tue Aug 29, 2017 4:21 pm
Different Computers offline
Re: Motion Triggers Enable/Disable
Are you familiar with the "Disable Trigger" action?
One of the actions when that switch is thrown could be to disable whatever action you don't want happening.
Wed Aug 30, 2017 4:48 am
qcvictor offline
Yes has been one of my first test, it's working but I'm stuck how re enable it after the disable ?
Wed Aug 30, 2017 6:24 am
On the action panel to disable the trigger there is a checkbox option and duration you can enter to have it automatically re-enabled later.
Thu Aug 31, 2017 3:56 pm
qcvictor offline
Hey Matt
You talk about the auto-on-after, right?
Doesn't work for me ...
Fri Sep 01, 2017 11:08 pm
No, the screenshot you posted shows the Turn Off action. qcvictor above is talking about the Disable Trigger action which is under the Server Actions type popup category. Once that action is selected (it allows you to disable Triggers) you will see the auto-Enable option which can be used to have the Trigger that gets disabled automatically re-enabled after a delay.
