Trigger to control exhaust fan with conditions
Sun Jun 04, 2017 6:38 am
BruceP offline
I wish to turn on my bath exhaust fan 1 min. after the shower lights come on. The fan will then run for 45 min. However if the light is turned on and then off within the first min. nothing is to happen.
I set a variable to reflect the light being on or off. I cannot seem to figure out the next step, since it needs a condition based on the verbal of the light on or off. Do I need two to three separate steps?
Sun Jun 04, 2017 11:02 am
Re: Trigger to control exhaust fan with conditions
Trigger 1: when the light turns on, no conditions, turn on exhaust fan with an auto off of 45 minutes and a delay of 1 minute
Trigger 2: when the light turns off, no conditions, remove delayed actions for Trigger 1
I think that's got it, right?
Tue Jun 06, 2017 5:08 am
BruceP offline
Thanks for the reply. I never knew the remove trigger command existed.
However I cannot seem to get the fan to turn no after the 45 min. I have triple checked that I followed your example, and still the fan does not turn off.
Bruce
Tue Jun 06, 2017 6:12 am
johnpolasek offline
Does the "Sent OFF command" show up in the event log?
Also, is the switch X10, Insteon, or Z-wave?
And can you turn it off from Indigo using a control page or the device window?
Tue Jun 06, 2017 7:38 am
BruceP offline
I am using RadioRa2.
I can turn the fan on and off from within Indigo
Fan does come on as expected.
There is no off received, and no delay action in the Schedules list
Tue Jun 06, 2017 9:53 am
Exactly how do you have the triggers configured?
Tue Jun 06, 2017 10:32 am
BruceP offline
Trigger 1 Master Shower Fan on Delay Device State Change, Shower lights, on/off becomes on> no conditions > Turn on Master fan delay 1 min, auto off 45 min
Trigger 2 Master Shower Remove Delay, Device State Changed, shower lights becomes off > no conditions > Remove for trigger Master Shower Fan Delay
Tue Jun 06, 2017 1:04 pm
And neither trigger fires when you turn the light on/off? Sounds like the device's state isn't getting updated.
Wed Jun 07, 2017 6:37 am
BruceP offline
Not sure what to say, but all is working currently. Will keep an eye on this.
Thanks for your help
Fri Jun 09, 2017 5:10 am
BruceP offline
New update with failures.
Did some tracking and it looked like turning off the lights removed the scheduled off command no matter what.
I added a variable for the fan, so if the fan was on (variable true) the trigger to remove the delay was not exicuted. Placed a timer to change the verbal back when the fan turned off when it should.
Not sure if this is the most elegant way, but seems to be working now.
