When does a trigger's condition get evaluated?
Mon May 22, 2017 12:28 pm
johnfdl offline
I am creating a trigger to auto-close my garage door. I have a variable called Autoclose which allows me to override the auto-close (if I am working in the garage for example). My question is are the conditions evaluated at trigger time or at action time? I ask this because I have the actions set to a 2 min delay (so I can clear the garage area). So if I open the garage door and 1 min later, set the GargeAutoclose variable to OFF, then will the condition which evaluates the variable be seen as ON or OFF?
Trigger
Conditions
Actions:
Mon May 22, 2017 1:01 pm
johnpolasek offline
Re: When does
I believe they are evaluated at trigger time; however, what you can do is have another trigger that when the cancelautoclose variable becomes true, removes delayed actions from the autoclose trigger.
Mon May 22, 2017 1:31 pm
johnfdl offline
Re: When does
Thanks. So to be clear, the "remove delayed actions" function.....does this simply skip the delayed action (preserving it for the next time the trigger is fired) or does it physically remove the delayed action? I am assuming the former, but the name makes me think it would eliminate it permanently (though it would be difficult to think of a use case for that)..
Mon May 22, 2017 1:56 pm
Re: When does a trigger's condition get evaluated?
When a delayed action executes (at trigger/schedule time), Indigo creates a special schedule action which will actually perform the action at the correct time (and delete itself when done) - you can see them in the UI starting with "_delay". When you remove delayed actions, that's what gets deleted. The delay specification (i.e. the description of when the action should actually occur) on the action remains intact.
Conditions are (as pointed out above) evaluated at trigger/schedule time.
Mon May 22, 2017 1:59 pm
johnfdl offline
Thanks Jay.....that makes sense and sounds like it will address my needs for this scenario.
