Calling Web function to delete trigger ( delayed trigger )..
Sat May 13, 2017 3:45 pm
Jann offline
Hi all..
This is a bit confusing so I'm gonna be verbose.
I am using ControlPlane to detect when my, my husband's or my tenant's iPhones are in on the network. I've found the best way to do this is to detect their "bonjour" signature on the network...but I have it looking for their mac address as well on WiFi and Bluetooth just in case. This is working great. When Control Plane senses the bonjur address or either mac address for BT or WiFi, Control Plane issues a call to:
http://mini.local:xxxx/variables/iPhoneJann
or
http://mini.local:xxxx/variables/iPhoneMike
or
http://mini.local:xxxx/variables/iPhoneMaura
and sends "home" as the variable value.
Control Plane has the OPTION to say "detect when they drop off the network" but cos of the way iOS handles going on/off the network when phone is locked, this does not work. The phone is still in the house and iOS simply powered down the radios which triggers Control Plane - not what I want...
SO I decided to go the timer route and I created the following in Indigo:
IF *variable* iPhoneJann becomes equal to "home"
condition: always
THEN *modify variable iPhoneJann set to "away"
DELAY BY 5 minutes.
The reason? Cos I figure if phone is not triggered ON network again by Control Plane w/in 5 min, we should assume user left the house.
BUT if Control Plane detects phone go back on w/in 5 min I get overlapping "delay timers" ... for instance:
11:00: Phone detected by Control Plane, issues call to INDIGO to variable iPhoneJann to HOME
INDIGO SETS TIMER AT 11:05 to change that variable back to AWAY
11:02: Well, what do you know, Control Plane detected phone again ... calls indigo, sets iPhoneJann (which is STILL at "HOME" status) to "HOME"
INDIGO SETS TIMER AT 11:07 to change that variable back to AWAY
11:05, EVEN THOUGH iPhoneJann is at home, and it's w/in 5 min of Control Plane LAST detecting it, INDIGO timer fires and sets variable iPhoneJann back to AWAY
11:07 INDIGO timer fires and sets variable iPhoneJann to AWAY even though it was AWAY (which is fine)
What I need is a call to indigo which does the following:
Set iPhoneJann to "HOME"
DELETE ANY "delay timers" at ALL that are automated and set iPhoneJann to AWAY
That would solve my issue.
Ideas?
Sun May 14, 2017 11:02 am
Re: Calling Web function to delete trigger ( delayed trigger
Rather than setting the variable directly, call an action group that sets the variable to home and sets the variable to away with a delay of 5 minute and make sure that you have the "Override previous delay" checkbox checked. That will keep the delay resetting as long as you continue to get messages that the phone is home. Otherwise, the delay will run out and the variable becomes "away".
Sun May 14, 2017 12:22 pm
Jann offline
Jay,
Thanks! I did this.
I'm getting a list of the attached _delayed_action's in my schedules window still.
Aren't they supposed to be deleted?
Here's my rule: (I did it at 7:30 time to better show all the delayed actions that stay in the list in schedules)
TIA
Jann
Screen Shot 2017-05-14 at 11.19.35 AM.png (276.88 KiB) Viewed 1914 times
Screen Shot 2017-05-14 at 11.19.30 AM.png (276.44 KiB) Viewed 1914 times
Screen Shot 2017-05-14 at 11.19.26 AM.png (225.9 KiB) Viewed 1914 times
Screen Shot 2017-05-14 at 11.18.30 AM.png (126.43 KiB) Viewed 1914 times
Sun May 14, 2017 2:08 pm
Jann offline
The symptoms I have SEEM to be related tho this (13 year old) issue.../that was fixed in a release...but do not seem to be working correctly wrt overriding previous delay...
viewtopic.php?p=2783#p2783
Cos this is exactly what I am seeing...Ideas?
May 14, 2017, 12:53:43 PM
   WebServer                       request to execute action group "IPhone Mike Home" from 10.0.1.100
   WebServer                       request to execute action group "IPhone Maura Home" from 10.0.1.100
   Action Group                    IPhone Mike Home
   Trigger                         Expire Phone Timer Mike
   Action Group                    IPhone Maura Home
   Trigger                         Expire Phone Timer Maura
May 14, 2017, 12:55:04 PM
   Schedule                        _delayed_action_7
May 14, 2017, 12:57:21 PM
   WebServer                       request to execute action group "IPhone Jann Home" from 10.0.1.100
   Action Group                    IPhone Jann Home
   Trigger                         Expire Phone Timer Jann
May 14, 2017, 12:58:28 PM
May 14, 2017, 12:58:43 PM
   Schedule                        Expire Phone Timer Mike (delayed action)
   Schedule                        Expire Phone Timer Maura (delayed action)
May 14, 2017, 12:59:41 PM
   Indigo Cocoa client authenticated (10.0.1.8)
   Z-Wave                          received "029 - Notification Sensor (Front Porch)" status update battery level 100%
May 14, 2017, 1:02:21 PM
   Schedule                        Expire Phone Timer Jann (delayed action)
May 14, 2017, 1:04:41 PM
May 14, 2017, 1:05:58 PM
   Schedule                        _delayed_action_6
May 14, 2017, 1:07:11 PM
   Schedule                        _delayed_action_5
Wed May 17, 2017 9:45 am
What are Expire Phone Timer Mike and Expire Phone Timer Jann? Are you sure that those aren't scheduling some future events also that are conflicting with your variable change action group? You can double-click those automatically generated schedules to see what the actions are - that should help identify what they're trying to do.
I'm 99.99% positive that the 13 year old bug was fixed back then...
