You can write a simple python script to show it:
- Code: Select all
for t in indigo.triggers:
indigo.server.log("{}: {}".format(t.name, t.enabled))
Which will print this to the Event Log window:
- Code: Select all
Interactive Shell HS-WD100+ Double tap on: True
Interactive Shell Master brightness device trigger: False
Interactive Shell Trigger w/ delayed action group: False
Interactive Shell Trigger w/ delayed action group cancel: False
where the True/False represents if it's enabled (I ran this in the interactive shell which is why that's what it shows for the log type). Use indigo.schedules for schedules. Of course, you can get a lot more fancy by writing to a file, etc., but that gets you started.
