[ANSWERED]Startup Script Weather NOAA sync
Mon Apr 03, 2017 9:13 am
jalves offline
I've got a server startup script (currently disabled) called "Weather NOAA sync.scpt" and was wondering if it was really needed. I've apparently been running just fine with out it and was about to simply delete this trigger but thought it might be worth checking here.
FWIW I looked at the script and it appears to date back quite a few years now, with the last update being 2008. Since there have been a few iterations of Indigo since then is it possible that this script isn't really needed? And yes, I do have the NOAA Weather plug-in enabled, although I'm considering moving all that to the excellent WUnderground plugin
Jeff
Mon Apr 03, 2017 9:44 am
Re: Startup Script Weather NOAA sync
The NOAA Weather plugin replaced the NOAA sync script in Indigo 5. The script is still installed for anyone that wants to use it (it should still work) but the plugin is better.
Mon Apr 03, 2017 10:33 am
jalves offline
Re: [ANSWERED]Startup Script Weather NOAA sync
Jeff
