Noob question - finding Indigo objects in an embedded script
Fri Nov 11, 2016 1:58 pm
turtle offline
I am a noob with Indigo, but I am enjoying the power of the Python scripting capability, its amazing what you can do with it.
I want to write a trigger that uses "X10/RF Command Received" from "Any address" received "Any Command". My plan is to create multiple X10 devices, each attached to a unique X10 address, but process them through the one trigger.
Question - Can the embedded script find the trigger object that caused it to be called? Is there something like
myTrigger = indigo.triggers.currentTrigger
Fri Nov 11, 2016 5:01 pm
Re: Noob question - finding Indigo objects in an embedded sc
As far as I know, the answer is no--although it's on the feature request list. One work around would be to use a variable. As a part of the trigger, change the value of the variable to the name of the calling trigger (or whatever you want). Then, within the script, you can check the value of the variable to see which trigger called it.
Screen Shot 2016-11-11 at 4.59.59 PM.png (33.36 KiB) Viewed 1341 times
Sat Nov 12, 2016 11:54 am
turtle offline
Thanks for the info. I'm a big DIO fan, but I guess this is what I must do.
