I am slowly but surely getting a handle on my mixed Insteon/Z-Wave control. I just installed the Insteon 74551 garage door control and status kit. Everything works -- I can raise and lower the door and I have a variable with the current door state. All good.
But I hate toggles. I don't want to be part of the control system. I don't want to have to manually check the state of the door before activating the toggle to put the door in the state I want it. I want to be able to say, "Open the door," or, "Close the door." After all, I have a computer to monitor the state and determine what should be done. If I say, "close the door," and the door is already closed, it should just stay closed. Likewise for "open the door."
It seems to me that, ideally, I should be able to check state before executing an action. It would make it so simple to do. And I can do that in a trigger but, apparently, not an action.
So I am at a bit of a loss. This seems to me like such a basic function that I suspect what I want to do is already built into Indigo and I have just missed it. Can someone please point me to it? And if there is a way to check status in an action group, or to simulate a trigger from the UI in order to use a trigger more like an action group, then that would help too.
Thanks in advance.
