mat wrote:UV level is available in the WUnderground plugin
Wunderground wrote:About the UV Index
The UV Index is a forecast of the probable intensity of skin damaging ultraviolet radiation reaching the surface during the solar noon hour: 11:30-12:30 Local Standard Time, or 12:30-13:30 Local Daylight Time. The greater the UV Index is the greater the amount of skin damaging UV radiation. How much UV radiation is needed to actually damage one's skin is dependent on several factors. In general, the darker one's skin is — that is, the more melanin one has in his/her skin — the longer (or the more UV radiation) it takes to cause erythema (skin reddening).
mat wrote:The Wunderground app shows me the lux level from the local weather station two roads away, but it doesnt appear in the plugin - now that would be useful!
mat wrote:Thanks Dave. Interesting, as the app is reporting it as lux
johnpolasek wrote:Of course if you've got a Z-stick on the system that's reasonably close to an an outside wall, you could spend the 50 bucks for one of the Aeon 4 in 1s that Indigo supports and ignore the motion while monitoring temperature and humidity as well as lux right in your own yard.
