Recommended Scene Controller?
Tue Sep 08, 2015 9:05 pm
Re: Recommended Scene Controller?
If you turn on Z-Wave debug logging checkbox (via Interfaces->Z-Wave->Configure... menu item), then press the buttons on the controller is anything logged? If so, copy/paste the results into a forum reply for me. It will help us create a device definition for it.
Wed Sep 09, 2015 6:16 am
Chockymonster offline
Z-Wave received "017 - Portable Remote Controller" status update battery level 100%
Z-Wave Debug . . nodeAwake: inhibit count-- to 0
Z-Wave Debug . . nodeAwake: stopping inhibit sleep timer
Z-Wave Debug SENT goToSleep: 01 09 00 13 11 02 84 08 04 EF 91
Z-Wave Debug RCVD packet: 01 05 00 13 EF 00 06 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 3F 00 03 80 (hex)
Z-Wave Debug RCVD nodeAwake: 01 08 00 04 00 11 02 84 07 63
Z-Wave Debug . . nodeAwake: node 017
Z-Wave Debug . . . . . . . : skipping battery check (next check in 717 mins)
Z-Wave Debug SENT goToSleep: 01 09 00 13 11 02 84 08 04 F0 8E
Z-Wave Debug RCVD packet: 01 05 00 13 F0 00 19 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 40 00 04 F8 (hex)
Z-Wave Debug SENT goToSleep: 01 09 00 13 11 02 84 08 04 F1 8F
Z-Wave Debug RCVD packet: 01 05 00 13 F1 00 18 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 41 00 02 FF (hex)
Z-Wave Debug SENT goToSleep: 01 09 00 13 11 02 84 08 04 F2 8C
Z-Wave Debug RCVD packet: 01 05 00 13 F2 00 1B (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 42 00 01 FF (hex)
Z-Wave Debug SENT goToSleep: 01 09 00 13 11 02 84 08 04 F3 8D
Z-Wave Debug RCVD packet: 01 05 00 13 F3 00 1A (hex)
that's what is in the log if I turn on debug.
That's every button pressed
Wed Sep 09, 2015 7:58 am
Great – it is sending unique scene messages out-of-the-box. Can you tell me what order you pressed the buttons for the above?
Wed Sep 09, 2015 8:31 am
That would have been helpful to note.....
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 4B 00 01 F6 (hex)
Z-Wave Debug SENT requestBatteryLevel: 01 09 00 13 11 02 80 02 05 06 77
Z-Wave Debug . . nodeAwake: inhibit count++ to 1
Z-Wave Debug . . nodeAwake: started inhibit sleep timer
Z-Wave Debug RCVD requestBatteryLevel: 01 09 00 04 00 11 03 80 03 64 07
Z-Wave Debug . . requestBatteryLevel: node 017, level 100
Z-Wave Debug SENT goToSleep: 01 09 00 13 11 02 84 08 04 07 79
Z-Wave Debug RCVD packet: 01 05 00 13 07 00 EE (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 4C 00 03 F3 (hex)
Z-Wave Debug SENT goToSleep: 01 09 00 13 11 02 84 08 04 08 76
Z-Wave Debug RCVD packet: 01 05 00 13 08 00 E1 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 4D 00 02 F3 (hex)
Z-Wave Debug SENT goToSleep: 01 09 00 13 11 02 84 08 04 09 77
Z-Wave Debug RCVD packet: 01 05 00 13 09 00 E0 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 4E 00 04 F6 (hex)
Z-Wave Debug SENT goToSleep: 01 09 00 13 11 02 84 08 04 0A 74
Z-Wave Debug RCVD packet: 01 05 00 13 0A 00 E3 (hex)
Ok, that was pressed in the following order, using the button labels in the manual.
1, 3, 2, 4
Wed Sep 09, 2015 9:02 am
I've not done any of the modifier presses of which there are 3 giving 16 total scenes. Do you want those too?
Wed Sep 09, 2015 10:01 am
Yep, it would be great to have the log showing all of them.
Wed Sep 09, 2015 10:36 am
Ok,
Here are all 4 buttons.
The button presses were identical.
Single Press
Double Press
Hold
Release
The skipping battery check is in between the single, double and hold. The release I can only assume is the last entry in the large block of received..
Button 1
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 4F 00 01 F2 (hex)
Z-Wave Debug SENT requestBatteryLevel: 01 09 00 13 11 02 80 02 05 20 51
Z-Wave Debug SENT goToSleep: 01 09 00 13 11 02 84 08 04 21 5F
Z-Wave Debug RCVD packet: 01 05 00 13 21 00 C8 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 50 03 01 EE (hex)
Z-Wave Debug SENT goToSleep: 01 09 00 13 11 02 84 08 04 22 5C
Z-Wave Debug RCVD packet: 01 05 00 13 22 00 CB (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 51 02 01 EE (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 52 02 01 ED (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 53 02 01 EC (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 54 02 01 EB (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 55 02 01 EA (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 56 02 01 E9 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 57 02 01 E8 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 58 02 01 E7 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 59 02 01 E6 (hex)
Z-Wave Debug SENT goToSleep: 01 09 00 13 11 02 84 08 04 23 5D
Z-Wave Debug RCVD packet: 01 05 00 13 23 00 CA (hex)
Button 2
9 Sep 2015 17:27:09
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 5A 00 02 E4 (hex)
Z-Wave Debug . . . . . . . : skipping battery check (next check in 716 mins)
Z-Wave Debug SENT goToSleep: 01 09 00 13 11 02 84 08 04 24 5A
Z-Wave Debug RCVD packet: 01 05 00 13 24 00 CD (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 5B 03 02 E6 (hex)
Z-Wave Debug SENT goToSleep: 01 09 00 13 11 02 84 08 04 25 5B
Z-Wave Debug RCVD packet: 01 05 00 13 25 00 CC (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 5C 02 02 E0 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 5D 02 02 E1 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 5E 02 02 E2 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 5F 02 02 E3 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 60 02 02 DC (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 61 02 02 DD (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 62 02 02 DE (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 63 02 02 DF (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 64 02 02 D8 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 65 01 02 DA (hex)
Z-Wave Debug SENT goToSleep: 01 09 00 13 11 02 84 08 04 26 58
Z-Wave Debug RCVD packet: 01 05 00 13 26 00 CF (hex)
Button 3
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 74 00 03 CB (hex)
Z-Wave Debug . . . . . . . : skipping battery check (next check in 715 mins)
Z-Wave Debug SENT goToSleep: 01 09 00 13 11 02 84 08 04 2A 54
Z-Wave Debug RCVD packet: 01 05 00 13 2A 00 C3 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 75 03 03 C9 (hex)
Z-Wave Debug SENT goToSleep: 01 09 00 13 11 02 84 08 04 2B 55
Z-Wave Debug RCVD packet: 01 05 00 13 2B 00 C2 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 76 02 03 CB (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 77 02 03 CA (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 78 02 03 C5 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 79 02 03 C4 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 7A 02 03 C7 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 7B 02 03 C6 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 7C 02 03 C1 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 7D 02 03 C0 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 7E 02 03 C3 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 7F 02 03 C2 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 80 01 03 3E (hex)
Z-Wave Debug SENT goToSleep: 01 09 00 13 11 02 84 08 04 2C 52
Z-Wave Debug RCVD packet: 01 05 00 13 2C 00 C5 (hex)
Button 4
9 Sep 2015 17:28:48
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 81 00 04 39 (hex)
Z-Wave Debug . . . . . . . : skipping battery check (next check in 714 mins)
Z-Wave Debug SENT goToSleep: 01 09 00 13 11 02 84 08 04 2D 53
Z-Wave Debug RCVD packet: 01 05 00 13 2D 00 C4 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 82 03 04 39 (hex)
Z-Wave Debug SENT goToSleep: 01 09 00 13 11 02 84 08 04 2E 50
Z-Wave Debug RCVD packet: 01 05 00 13 2E 00 C7 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 83 02 04 39 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 84 02 04 3E (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 85 02 04 3F (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 86 02 04 3C (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 87 02 04 3D (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 88 02 04 32 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 89 02 04 33 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 8A 02 04 30 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 8B 02 04 31 (hex)
Z-Wave Debug RCVD requestReply1: 01 0B 00 04 00 11 05 5B 03 8C 02 04 36 (hex)
Z-Wave Debug SENT goToSleep: 01 09 00 13 11 02 84 08 04 2F 51
Z-Wave Debug RCVD packet: 01 05 00 13 2F 00 C6 (hex)
Wed Sep 30, 2015 6:28 am
ToonDoom offline
I'm tempted to get of these. They look good. Any update on compatability?
Wed Sep 30, 2015 6:39 am
I've not heard anything yet.
Wed Sep 30, 2015 12:34 pm
Fordy offline
I'll be making a purchase when I find they're compatible too! ;)
Wed Sep 30, 2015 12:39 pm
The units themselves are lovely, really nice feel to them. I can't wait to get them working!
Wed Sep 30, 2015 12:41 pm
Fordy offline
Haha it's a good job they are lovely and feel nice though since that's all you can do with 'em right now! ;)
Wed Sep 30, 2015 12:44 pm
Trust me, the mounting magnetic base is very nice to play with :)
Sat Oct 10, 2015 1:15 am
noel1983 offline
Hi all,
Is there any update on these? I've bought one of each from Vesternet to have a go at getting them going.
These are exactly what i've needed to replace X10 stick a switches so be great once we can get them working!
Matt/Jay, if there's any info I can provide for any or all of the three nodon wave switches let me know.
Noel
Sat Oct 10, 2015 1:17 am
noel1983 offline
Meant to say I haven't manage to get mine synched yet.
My wave usb stick associates all ok, then when I add a device in Indigo it see's it ok but gives me a 'No Response - unit might be asleep' message.
Not sure how to keep the unit awake for the Indigo portion of adding the device!
Cheers
