Philips Hue controlled by movement - but color by variable
Sun Aug 16, 2015 4:21 am
indigo2200 offline
A movement sensor turns on 3 Philips Hue bulbs when Sensor is ON and Lumens is under a certain threshold. All this work well. But I would like to add a rule or more precise a Variable. If the Variable is "awake" the light tun on normal (100 percent), if the Variable is "sleep" the light will only turn on 50 percent and with a red color.
Can any one please indicate roughly how to do this?
Sun Aug 16, 2015 7:54 am
jalves offline
Re: Philips Hue controlled by movement - but color by variab
How about two nearly identical triggers. One that works during daylight and the other that works at night?
Jeff
Mon Aug 17, 2015 9:38 am
indigo2200 offline
Thanks. That is what I did. I also made a variable controlled by a virtual device. The variable controllers which Trigger (through condition) will executive either day or nighttime light scheme.
