Do Action if variable is still the same after five minutes
Tue May 05, 2015 12:43 pm
noel1983 offline
Hi all,
I'm on the case detecting the power usage of a tumble dryer so that five minutes after power usage drops to less than 5 watts Indigo sends me a message to say that the Drying is finished.
I can set the variable TumbleDryerOn to be true and false based on the power usage no problem, the bit I don't know how to do is to check after five minutes if the variable is still false so as to then send the message.
Reason I want the delay is sometimes the dryer pauses and changes direction which I have a suspicion will result in 0W for a few seconds.
Can anyone help me out?!
Noel
Tue May 05, 2015 12:49 pm
RogueProeliator offline
Re: Do Action if variable is still the same after five minut
Others will correct me if I have missed anything, but I would attempt to tackle this by creating a Timer device that is set to 5 minutes. Whenever you variable changes to "false", you will start the timer... any time it goes to true (meaning the dryer is on) you will stop the timer in case it is running from a "pause" as you think may happen. When the timer completes you know that it has been off 5 minutes from having going to "false" and can send the notification.
Adam
Tue May 05, 2015 1:21 pm
noel1983 offline
Hi Adam,
Perfect thanks, I knew there was some nugget of knowledge I was missing! That's working perfectly.
Cheers for the awesomely fast response!
Noel
Sun May 24, 2015 3:40 pm
jens offline
Nice, can you do a scream dump how you did, is new on this...
Mon May 25, 2015 5:13 am
noel1983 offline
tumble dryer actions.tiff
tumble dryer actions.tiff (281.48 KiB) Viewed 4314 times
tumble dryer triggers.tiff
tumble dryer triggers.tiff (306.03 KiB) Viewed 4314 times
Two screenshots hopefully attached!
The first shows the conditions, the second the actions for the three triggers.
So what happens is as follows
When power consumption of tumble dryer goes above 500W (it normally sits about 0.2W when off) make variable TumbleDryer = On AND stop timer
When power consumption of tumble dryer goes below 5W make variable TumbleDryer = Off AND start timer TumbleDryerOffFor5Minutes with start time of 5 minutes.
When timer reaches 0 send email notifications to boxcar which then sends push notifications to our phones.
The reason for the timer and not simply sending a notification as soon as power drops is sometimes it will pause for a little while change direction etc.
This means that when it stops, timer starts, if it starts again timer stops and resets.
Once its been stopped for 5 minutes notifications are sent.
Hope this helps
Cheers
Noel
Mon May 25, 2015 11:09 pm
jens offline
Thanks Noel,
Try it to day...
:D
//Jens
Tue May 26, 2015 12:52 am
jens offline
Noel,
You have a Pause trigger whats that??
Tue May 26, 2015 1:19 am
noel1983 offline
I think that's from when I was getting to grips with the timers and figuring out how best to set this up. It's no longer required! Good spot
Cheers
Tue May 26, 2015 2:35 am
jens offline
OK, now it works
Sun May 31, 2015 8:44 pm
midd offline
so how would I get it to work for multiple variables still the same?
I get the gist of the preceding posts. But I'm using the beacon plugin and geohopper and I need the timer to start (20 minutes) once indigo sees my phone and my wife's phone are away. Once the 20 minutes are up and we are both still away, I want to change my heating and cooling settings.
Indigo 7, Monterey (12.1) on a 2009 Mac Pro..
Sun May 31, 2015 11:27 pm
noel1983 offline
Something along the lines of
When person 1 away check if person 2 away, If yes start timer
And vice versa if person 2 away check if person 1 away, if yes start timer
When timer reaches 0 turn off heating etc
When person 1 or 2 comes home then stop/reset timer, that then covers you if someone leaves and comes back quickly.
There may be better ways to do this so I'm sure more experienced minds will be along soon!
Sun May 31, 2015 11:46 pm
each of your phone should start a trigger with a delayed action (20 minutes) if they are away, with condition that the other is away too.
if one of them comes back online you trigger a server/removed delayed action that removes the delayed action from the triggers above.
So I guess you would need 4 triggers, 2 for each phone: offline and back online.. off line starts a DELAYED action and online kills these actions.
and the action group should be a common action group i.e. change heater to away.
Another way could be to have one variable that gets increased / decreased by your phones changing to offline / online & condition:
one trigger checking if variable =2 then start delayed action group..
one trigger checking if variable <2 then kill delayed action group
no matter what I guess you need 4+ triggers.
Mon Jun 01, 2015 6:23 am
midd offline
ok thanks. I think I have it.
Before my post, I had 5 triggers set up. 2 for each phone, 1 for being home, 1 for being away. The 5th would tell indigo to switch my housemode variable to vacation after we have been gone for twenty minutes.
So I used Karl's suggestion and created another variable, Phones not home. As each phone leaves the variable increases by 1 and decreases by 1 when each one returns home. When the value reaches 2, the 20 minute timer begins.
After 20 minutes that 5th trigger would kick in.
The more I look at it now, I only need the one variable, Phonesnothome. I'm also using the Myphone and myifesphone to show True or False depending on if we are present or absent. Phonesnothome is doing the triggering at a value of 2. The other two really aren't contributing to what I want done.
