I have an Insteon motion sensor in my garage that turns on the lights, which are controlled by two dual-band Insteon switches. I'd like the garage lights to go on and off under the control of the motion sensor EXCEPT when I use a switch to turn them on, even if I tap the top (ON) of the paddle (double-tap would be okay, too) on the switch after the motion sensor has turned on the lights. Can this be achieved in Indigo? That is, can a set-up a trigger action, "ignore motion sensor OFF command if switch was tapped ON (or double-tapped)"?
Thank you!
