{SOLVED] Using X10 triggers to execute Insteon commands
Tue Sep 16, 2014 7:24 pm
nclemmons offline
I have migrated from x10 to Insteon devices. But I still have several x10 keypads on tables.
I'd like to use these keypads which have 8 locations, on, off, bright, dim, all on, all off buttons.
So I want to be able to trigger something like:
When the E1 x10 command is pressed On, turn on the Insteon based family room lamp.
I've done this in Indigo - running version 6.0.13 with a Smarthome PLM via USB on a Mac Mini.
But I can't get any response. I see no log of x10 commands showing up in the log file on Indigo. And the Insteon command does not execute.
Ideally, I'd have 16 of these triggers - one for each button for both on and off x10 sensing to trigger a corresponding Insteon command.
Thanks for any advice you can offer.
neil
Tue Sep 16, 2014 8:59 pm
ELWOOD offline
Re: Using X10 triggers to execute Insteon commands
neil
I have been doing this for years and it works well. Have used the x-10 keypads to fire triggers. Also have been able to get triggers fired from
Ademco/Honywell Vista Alarm panels. The vista panels can be programed to send x-10 signals for most of the panels conditions which can than
fire triggers in indigo.
However I have had trouble with the insteon power link modems over the years. The insteon part of the modem keeps working fine but it stops
sending and receiving the x-10 signals. Since you are not seeing the x-10 in the logs you probably have a bad power link.
I would try a new one.
Hope this helps
Elwood
Tue Sep 16, 2014 9:32 pm
neil
Silly question perhaps - are they plugged in or battery powered?
Wed Sep 17, 2014 8:40 am
nclemmons offline
Jay - They are 110v powered keypads - going back to x10 at RadioShack days.
Elwood - Thanks, I may have to upgrade the Powerlinc PLM.
Any other thoughts from the forum?
Neil
Wed Sep 17, 2014 8:06 pm
nclemmons offline
I ordered a replacement PLM. I kept getting a disconnected message and was resetting it several times.
Must be a faulty unit. So I'll replace tomorrow and see if that fixes the triggers.
Thanks for the feedback.
neil
Wed Sep 17, 2014 11:43 pm
ckeyes888 offline
I use quite of few of the X10 PalmPads as well and have found the W800RF receiver to be much faster
and more reliable than any PLM I've tried.
Just my 2¢.
Carl
Thu Sep 18, 2014 7:35 am
I agree 110% with Carl on the W800RF32.
Just a note that it only receives X10 RF commands and not X10 power line commands. This makes it much faster (instantaneous versus 1 or 2 second delay), but means only PalmPad, keyfob, and other battery operated modules will be received by it. If you are using a X10 MaxiController then the command has to get to Indigo over the power line.
Thu Sep 18, 2014 9:48 pm
nclemmons offline
Replacement USB PLM arrived today and now I get triggered responses to x10 commands.
I have both x10 wired keypad and the keychain wireless X10 remotes and both work fine for me.
Appreciate the suggestion.
Thanks -
neil
