[ANSWERED]: newbie question - battery notify, heating sync..
Sun Jun 23, 2019 12:11 pm
captcurrent offline
Re: [ANSWERED]: newbie question - battery notify, heating sy
thanks for the quick response
I made an other action group just to double check sending mail
it is working fine
I know I have at least one insteon with low battery as it keeps smiling me. no idea which one
Sun Jun 23, 2019 6:00 pm
My guess is that there's something hinky with the conditional -- unfortunately, I don't have any Insteon devices to test against. Hopefully someone will be able to knock this one for you.
Mon Jun 24, 2019 5:47 am
I did a little more research on the forums, and it looks like Insteon devices may not report a battery level percentage like Z-Wave devices do. I don't know if this is universal for all Insteon devices or only the one discussed in the thread (I expect the former). In which case, it looks like Insteon devices will send out a battery low alert, so the conditional will have to watch for that flag (whatever it may look like).
This is all conjecture, though, and will need to be confirmed by someone with Insteon experience.
Mon Jun 24, 2019 7:21 am
captcurrent offline
Thanks. I know I have a device telling me it hs. low battery just can't find it.
Wish you script worked .. its perfect
Mon Jun 24, 2019 8:58 am
Insteon devices don't report battery percentage. The best they can do is send a battery low notification which you can catch in a Trigger. But even that is quite unreliable. Another reason we don't recommend using battery powered Insteon devices if you can find Z-Wave alternatives.
Mon Jun 24, 2019 9:04 am
captcurrent offline
actually this script didn't report the state of my battery z-wave door
I have been playing with your battery reporting script (viewtopic.php?f=78&t=12578&p=178876#p178876). with no luck either
Guess I will live it.. I still would like to figure which device is sending me the lower battery email
Thu Apr 23, 2020 3:12 am
jaknudsen offline
Dual wrote:
I have already modified your code and scheduled it to send one email with the state of all batteries (i.e. even if 100%).
I would be really grateful if you could share your modified script :)
I found another script, but this also includes devices that are not battery powered: http://blog.homeautomation-direct.co.uk ... ry-devices
## Check devices battery levels
# Set the target battery level and the email address to notify
TargetLevel=25
EmailAddress="example@example.com"
LowBatteryCount=0
# Shortcut the log function
def log(msg):
 indigo.server.log(msg, type="Low Battery Notification Script")
log ("Starting check")
emailBody="The following devices have low batteries: \r\n\r\n"
# Loop round all the devices
for dev in indigo.devices.itervalues():
 if (dev.batteryLevel != None) and (dev.enabled):
 log (emailBody)
 if (dev.batteryLevel < TargetLevel):
 log ("Device below threshold, sending email")
 emailBody=emailBody+"\t"+(u'%s (battery level: %s' % (dev.name, dev.batteryLevel)) + "%)\r\n"
 LowBatteryCount+=1
emailBody=emailBody+"\r\n-End-"
if LowBatteryCount >0:
 indigo.server.sendEmailTo(EmailAddress, subject="Indigo battery alert", body=emailBody)
log ("Finished check")
Thu Apr 23, 2020 4:38 am
captcurrent wrote:
This is exactly what I want
But as usual. I just don't seem to get it
To test I added an action group with the following script
targetLevel = 100
emailAddress = "reallyme@somewhere.com"
   if dev.batteryLevel:
      if dev.batteryLevel < targetLevel:
         emailBody = (u'%s battery level: %s' % (dev.name, dev.batteryLevel))
         indigo.server.sendEmailTo(emailAddress, subject="Indigo Low Battery Alert", body=emailBody)
I added a schedule. and figured with 100 thresh hold I would get a good start position
Log says its is running my no email or errors in log
It has to be something simple I am not doing . Thoughts or suggestions?
Looking back through this thread, I see one thing that escaped me last time. This modified script (with target level of 100) won't include devices that have a battery level of 100. This is because the logic says to include devices with battery levels less than the target level. There are two ways you can fix this. The first is simply to set the target level to 101. The second is to change the logic from this:
to this:
      if dev.batteryLevel <= targetLevel:
Thu Apr 23, 2020 10:34 am
Dual offline
emailAddress = "me@me.com"
emailBody="BATTERY UPDATE."
         emailBody = emailBody + "\n \n" + str(dev.batteryLevel) + " ... " + dev.name
indigo.server.sendEmailTo(emailAddress, subject="BATTERY UPDATE", body=emailBody)
