Quick Question - SensorValue.ui
Sun Nov 06, 2022 3:56 am
mwoodage offline
Hello,
A quick question what's the difference between SensorValue and SensorValue.ui?
This is coming up from a Fibaro Implant sensor that i'm using to control my central heating temperature.
Just wondered what the difference was, :)
Thanks in advance
Martin
Screenshot 2022-11-06 at 09.48.58.png (23.16 KiB) Viewed 1137 times
Sun Nov 06, 2022 4:50 am
neilk offline
Re: Quick Question - SensorValue.ui
This allows you to have a UI display version of a state, it would not be used in triggers or logic but allows you for example to append degrees C to the numeric value so it looks correctly formatted.
When in a plugin you update the device state you can provide both values, not sure how it is configured for your device.
Neil
Sun Nov 06, 2022 7:27 am
mwoodage offline
Ah got it! Makes sense really :D
Thanks Neil,
Martin
