Homeseer HS-WX300 nightlight/mirrors load parameter
Sun Aug 28, 2022 2:36 pm
t-star offline
Looks like the parameter for the nightlight / mirrors load has been flipped for this device from the previous ones. I have it on nightlight (per Indigo) and when the switch is off all the LEDs are off.
Here is the device settings.
batteryLevel : None
blueLevel : None
brightness : 0
buttonConfiguredCount : 0
buttonGroupCount : 0
configured : True
defaultBrightness : 100
description : 076 - Dimmer Switch (HS-WX300)
deviceTypeId : zwDimmerType
displayStateValRaw : 0
displayStateValUi : 0
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 142208133
com.perceptiveautomation.indigoplugin.zwave : (dict)
HasControllableLEDs : true (bool)
NumberOfLEDs : 7 (integer)
address : 76 (integer)
indigoObjVersion : 10 (integer)
modelNameAndFirmware : Dimmer Switch (HS-WX300), firmware 1.13 (string)
propsPushTickler : 1 (string)
tempAlwaysFalse : false (bool)
userConfigVal003 : 0 (integer)
userConfigVal004 : false (bool)
userConfigVal006 : false (bool)
userConfigVal011 : 3 (integer)
userConfigVal012 : 2 (integer)
userConfigVal013 : 0 (integer)
userConfigVal014 : 3 (integer)
userConfigVal032 : 0 (integer)
userEnergyPollingEnabled : false (bool)
userPollInterval : 0 (integer)
userPollingEnabled : false (bool)
userWakeInterval : 60 (integer)
version : 1.13 (string)
zwAppVersMajor : 1 (integer)
zwAppVersMinor : 13 (integer)
zwAssociationsMap : (dict)
g1 : (list)
Item : 1 (integer)
g2 : (list)
zwAssociationsMapStr : 1:[1] 2:[] (string)
zwClassCmdBase : 38 (integer)
zwClassCmdMap : (dict)
c108 : 1 (integer)
c112 : 1 (integer)
c114 : 1 (integer)
c115 : 1 (integer)
c122 : 1 (integer)
c133 : 1 (integer)
c134 : 1 (integer)
c135 : 1 (integer)
c142 : 1 (integer)
c159 : 1 (integer)
c32 : 1 (integer)
c38 : 4 (integer)
c85 : 1 (integer)
c89 : 1 (integer)
c90 : 1 (integer)
c91 : 1 (integer)
c94 : 1 (integer)
zwClassCmdMapStr : 20v1 26v4 5Ev1 85v1 59v1 5Av1 7Av1 87v1 72v1 8Ev1 73v1 9Fv1 6Cv1 55v1 86v1 70v1 5Bv1 (string)
zwClassIds : (list)
Item : 4 (integer)
Item : 17 (integer)
Item : 0 (integer)
zwClassInstanceCountMap : (dict)
zwClassInstanceCountMapStr : - none - (string)
zwClassName : Mulitlevel Switch (string)
zwConfigVals : (dict)
p11 : 3 (integer)
p12 : 2 (integer)
p13 : 0 (integer)
p14 : 3 (integer)
p3 : 0 (integer)
p32 : 0 (integer)
p4 : 0 (integer)
p6 : 0 (integer)
zwConfigValsStr : 32:0 4:0 6:0 11:3 12:2 13:0 3:0 14:3 (string)
zwDevSubIndex : 0 (integer)
zwEncryptClassCmdMap : (dict)
zwEncryptClassCmdMapStr : - none - (string)
zwEncryptionStatusStr : Not Supported (string)
zwEndpointClassMap : (dict)
zwEndpointClassMapStr : - none - (string)
zwEndpointDevTypeMap : (dict)
zwEndpointDevTypeMapStr : - none - (string)
zwFeatureListStr : routing, beaming (string)
zwLibType : 3 (integer)
zwManufactureId : 12 (integer)
zwManufactureName : HomeSeer (string)
zwModelDefnVers : 1 (integer)
zwModelId : 1145520182 (integer)
zwModelName : Dimmer Switch (HS-WX300) (string)
zwNodeNeighbors : (list)
Item : 28 (integer)
Item : 29 (integer)
Item : 31 (integer)
Item : 32 (integer)
Item : 33 (integer)
Item : 34 (integer)
Item : 38 (integer)
Item : 46 (integer)
Item : 47 (integer)
Item : 49 (integer)
Item : 52 (integer)
Item : 60 (integer)
Item : 62 (integer)
Item : 63 (integer)
Item : 73 (integer)
Item : 74 (integer)
Item : 75 (integer)
zwNodeNeighborsStr : 28, 29, 31, 32, 33, 34, 38, 46, 47, 49, 52, 60, 62, 63, 73, 74, 75 (string)
zwProtoVersMajor : 7 (integer)
zwProtoVersMinor : 15 (integer)
zwShowDumpDevToLog : true (bool)
zwShowEnergyPollingUI : false (bool)
zwShowMainUI : true (bool)
zwShowManualModifyConfigParmUI : false (bool)
zwShowPollingUI : false (bool)
zwShowSubmitModelInfoUI : false (bool)
zwShowWakeIntervalUI : false (bool)
zwWakeInterval : 0 (integer)
greenLevel : None
lastChanged : 2022-08-28 14:15:33
lastSuccessfulComm : 2022-08-28 14:15:33
ledStates : []
model : Dimmer Switch (HS-WX300)
onBrightensToDefaultToggle : False
onBrightensToLast : True
onState : False
ownerProps : com.perceptiveautomation.indigoplugin.zwave : (dict)
g1 : (list)
Item : 1 (integer)
g2 : (list)
c108 : 1 (integer)
c112 : 1 (integer)
c114 : 1 (integer)
c115 : 1 (integer)
c122 : 1 (integer)
c133 : 1 (integer)
c134 : 1 (integer)
c135 : 1 (integer)
c142 : 1 (integer)
c159 : 1 (integer)
c32 : 1 (integer)
c38 : 4 (integer)
c85 : 1 (integer)
c89 : 1 (integer)
c90 : 1 (integer)
c91 : 1 (integer)
c94 : 1 (integer)
zwClassIds : (list)
Item : 4 (integer)
Item : 17 (integer)
Item : 0 (integer)
p11 : 3 (integer)
p12 : 2 (integer)
p13 : 0 (integer)
p14 : 3 (integer)
p3 : 0 (integer)
p32 : 0 (integer)
p4 : 0 (integer)
p6 : 0 (integer)
Item : 28 (integer)
Item : 29 (integer)
Item : 31 (integer)
Item : 32 (integer)
Item : 33 (integer)
Item : 34 (integer)
Item : 38 (integer)
Item : 46 (integer)
Item : 47 (integer)
Item : 49 (integer)
Item : 52 (integer)
Item : 60 (integer)
Item : 62 (integer)
Item : 63 (integer)
Item : 73 (integer)
Item : 74 (integer)
Item : 75 (integer)
pluginId : com.perceptiveautomation.indigoplugin.zwave
protocol : ZWave
redLevel : None
remoteDisplay : True
states : States : (dict)
brightnessLevel : 0 (integer)
subModel :
subType :
supportsAllOff : False
supportsColor : False
supportsRGB : False
supportsStatusRequest : True
supportsWhite : False
version : 1.13
whiteLevel : None
whiteLevel2 : None
whiteTemperature : None
Fri Mar 17, 2023 4:12 pm
Re: Homeseer HS-WX300 nightlight/mirrors load parameter
Hey, I don't have one of those to test - can you check out the HomeSeer brand specific control actions and see if it works with those? I suspect they do, but the docs aren't quite as clear on some of the functionality that we use to implement those actions.
Fri Mar 17, 2023 9:33 pm
t-star offline
I’ll try to work on that this weekend
Sat Mar 18, 2023 9:17 am
Much appreciated.
Sun Mar 19, 2023 9:57 am
t-star offline
so doing it that way is also reversed. See screenshot of how I tried it. when I run that it puts it in "normal load mode" not nightlight. but I'll be honest. I wouldn't do anything about it until you hear more people complain or you can obtain an answer from Homeseer. I would really be surprised if they meant to switch it and could probably be fixed in a firmware update. But I have trouble doing those without any windows machines in the house so I have not even looked to see if they have an update..
Screenshot 2023-03-19 at 11.43.12 AM.png (146.25 KiB) Viewed 2221 times
Sun Mar 19, 2023 11:26 am
Thanks. Would you mind trying the other actions as well (LED color, etc)?
Sun Mar 19, 2023 1:58 pm
t-star offline
the others seem to work as expected. just the nightlight one is reversed. I have several of the 200 series as well. so that is why I noticed the difference of the nightlight.
Mon Mar 20, 2023 2:06 pm
Thanks. I'll look into the original issue.
