Any recommendations on what Appliance module to purchase
Mon Aug 17, 2020 10:14 am
jroach offline
I was looking through the dozens of supported indigodomo devices and was hoping I could get some practical advice.
My requirements are:
-Controls of a Whole House fan, single speed
-Module could be a plug (Attic temps exceed 120) or at the switch (Hall).
-115v, US
-Would like Alexa control but not a must
Use: If (upstairs temp) is > outside temp by (x degrees) then enable
I was looking at the Insteon product (Insteon smart on/off Plug-in-module) as it has Alexa control but limited to 122 degrees.
Thanks in advance.
Mon Aug 17, 2020 10:23 am
Dual offline
Re: Any recommendations on what Appliance module to purchase
Are you running a z wave system or other?
Sun Aug 23, 2020 10:12 am
jroach offline
Dual,
Thanks in advance.
I have a little bit of everything (X10/UPB, wifi, zwave, BLE/Bluetooth, Zigbee...).
Sun Aug 23, 2020 11:00 am
jalves offline
I'd replace the wall switch with either a Insteon on/off switch OR a z-wave switch. Decision would be based on what I had in my spare inventory AND if though I needed a "repeater" device in my Insteon or Z-wave network. Currently leaning more towards z-wave because of a more robust device communication scheme.
Jeff
Sun Aug 23, 2020 11:01 am
Dual offline
I am all Z Wave.
I have recently bought a couple of Zooz Zen25. Good price for two outlets that can be controlled separately (USB port is not controlled just monitored). IIRC it’s only good for 10 amps. Nice form factor that does not block the other outlet.
Zooz Z-Wave Plus S2 Double Plug ZEN25, 2 Outlets, 1 USB Port https://www.amazon.com/dp/B07MVX4M2Q/
I have a large number of the Monoprice plugs and the Zooz ZEN06 which appear to be the same product. They are large and if installed in the top half of a wall receptacle they cover the bottom half. You can’t use two at one wall receptacle due to size. IIRC it will handle a 15 amp load.
Monoprice Z-Wave Plus Smart Plug and Repeater with 2 USB Ports https://www.amazon.com/dp/B076HZG5HR/
I have a Zooz ZEN20 power strip. So far it’s a good unit. Though the plugins aren’t far enough apart to handle power adapters well.
Zooz Z-Wave Plus S2 Power Strip ZEN20 VER. 2.0 with Energy Monitoring and 2 USB Ports, Works with Vera, Wink, SmartThings https://www.amazon.com/dp/B01HAQHQ5I/
I have one ZLINK Plug-in Appliance Module ZL-PA-100. It works fine. Kind of ugly and boxy looking though. It will take a 15A resistive load.
ZLINK Plug-in Appliance Module ZL-PA-100 https://www.amazon.com/dp/B07DFQR6K5/
I have one of the NEO Z-Wave Plus Smart Mini Power Plugs in use. After reading about some that have combusted I was scared away from them. Great feature is their small size. IIRC they may not act as a range extender though. Bad feature is they might ignite. The one I am using has nothing plugged into it. I am using it as an indicator light basically. I wish I could trust them since their form factor is awesome.
NEO Z-Wave Plus Smart Mini Power Plug Zwave Socket Zwave Outlet With Timing and Energy Monitoring Home Automation, Work with Wink, SmartThings, Vera, Fibaro & more, Green&Blue 2PK https://www.amazon.com/dp/B0794T2Z24/
I have one of the Zooz ZEN15 power switches. Very different form factor. Meant for heavy duty loads. Works fine.
Zooz Z-Wave Plus Power Switch ZEN15 for 110V AC Units, Sump Pumps, Humidifiers, and More https://www.amazon.com/dp/B07578W7KY/
I have a couple of the Aeotec Smart Switch 6. Great form factor. Good brand. Well built solid units. Very pricey. I use them where space won’t allow bigger units. Did I mention pricey lol?
Aeotec Smart Switch 6, Zwave Switch Z-Wave Plus Plug 15A for Home Security Automation Z-Wave Power Monitor, Without USB Port https://www.amazon.com/dp/B07PJNL5DB/
I have a couple of the a Leviton units. They reposition the plugin by 90 degrees.
Leviton DZPA1-2BW Decora Smart Plug-in Outlet with Z-Wave Technology, White, Repeater/Range Extender https://www.amazon.com/dp/B01NAO4B9Z/
I have a few wall switches in use as well. Both Honeywell and GE. They work fine. Though I have had issues when the electrical wall box is metal (Alberta) as opposed to plastic (Arizona). The signal strength can be an issue in metal boxes.
Honeywell UltraPro Z-Wave Plus Smart Light Switch, In-Wall White & Almond Paddles | Built-In Repeater Range Extender | ZWave Hub Required - Alexa and Google Assistant Compatible, 39348 https://www.amazon.com/dp/B07B3LY1SJ/
GE Enbrighten Z-Wave Plus Smart Light Switch with QuickFit and SimpleWire, 3-Way Ready, Works with Alexa, Google Assistant, ZWave Hub Required, Repeater/Range Extender, White & Light Almond, 46201 https://www.amazon.com/dp/B07RRBT6W5/
Sun Aug 23, 2020 11:14 am
Never use a plug module on an outlet controlled by a switch. That leads to madness....
Sun Aug 23, 2020 9:17 pm
jroach offline
Dual, thanks. I'll look into the Leviton device. Need to get back up in the attic to look at the peak for the motor. The other units appeared to be more for lights.
Jalves, agree with the recommendation for z-wave.
