I have two SwitchLincs set up in a three way circuit. Each at the end of a hallway. I've linked them through Indigo. One I call master, the other slave. Manually if I activate them from either end of the hall everything works exactly as expected. Lights come on/off, the multi LED dimmer displays work correctly on both SwitchLincs.
In Indigo, thing get a little weird. If I click on the "master" SwitchLinc, the lights go on, and the LED dimmer indicator on the "master" switch works correctly. However on the "slave: the LED indicator stays in the off position. If I click on the "slave" SwitchLinc, the lights don't go on, the LED indicator on the "slave" shows an on indication, but the "master" LED is still in the off position.
Also, In the Indigo device linking process why does a controller device get created when I enter a responder? Or is it just picking it up from the drop down list? I did cross link both devices, the master to the slave, and also the slate device to the master.
Is this normal behavior?
