Help with JSon Somfy Command
Sat Jun 16, 2018 5:01 pm
Re: Help with JSon Somfy Command
Out of interest, can you use remote to send a command, then do a Read()
Interested if it says owt.
Sun Jun 17, 2018 6:42 am
norcoscia offline
What device are you using to generate the RTS signals? The Mylink is a bridge - wireless IP on one side and an RTS (radio) on the other. What type of mothers do you have - Somfy makes a ton of interfaces for their motors - my awning use RTS.
I'll try the read today - there are also a bunch of % signals that are supposed to send the curtains (or awnings) to a spot based on the % order - I'll look it up today and let you know how it might work.
Site that has Somfy integration interfaces and some pictured below....
https://www.somfysystems.com/products/integration
_______
Norm
Sun Jun 17, 2018 9:38 pm
I don’t have any Somfy, though if I get this working (and if it works in UK) I’m looking at up to 8 motors for conservatory.
I’ve got 16 Somfy Blinds in theatre at work, theoretically controlled by RS485 to a Somfy Bridge, so I’m familiar with RTS channels and groups and (theoretically) programmable control - it just ain’t working :).
Let me know about move.to etc.
Mon Jun 18, 2018 7:40 am
norcoscia offline
I would think you need to be at work to test the telnet connection (with the Somfy Serial bridge) - The bridge should respond to the telnet commands the same way the MyLink bridge does - but it will have a serial output vice and RTS RF output.
I tried doing the read just now and had a bit of a train wreck - I first did an extend and planned to do a read while the awning was in motion. When I did the extend the plug-in errored out (see below) - Then right after the error I did a read and the log filled with keep alive messages in about 2 seconds - I had to cut most of them out to get this message small enough to send. The messages stoped and I tried the extend again - errored again but with a different error.
Then I reloaded the plug-in and tried an extend - worked great and did a read wile the motor was moving. Did a retract and again while the motor was moving did another read. It does not look like much info is coming back in the read - I have not looked at the code in .1 - are you trying to do a status?
Thanks for all the help with this and my mouser Peter.... Let me know if you wanted the read command to be done differently. (all returned data below)
   Trigger                         Somfy Extend
   Somfy Manager BETA Debug        myLinkCmdSingle action called:
   Somfy Manager BETA Debug        Target device: AABBCC.1
   Somfy Manager BETA              Sending payload:  { "id":1, "method": "mylink.move.down", "params": { "auth": “XXXX”, "targetID" : “AABBCC.1”} }
   Somfy Manager BETA Error        Error in plugin execution ExecuteAction:
  File "plugin.py", line 105, in myLinkCmdSingle
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/telnetlib.py", line 416, in read_very_eager
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/telnetlib.py", line 576, in fill_rawq
error: (54, 'Connection reset by peer')
   Trigger                         Somfy Read
   Somfy Manager BETA Debug        myLinkRead action called:
   Somfy Manager BETA Debug        Reply: {"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}{"method":"mylink.status.keepalive"}
  File "plugin.py", line 100, in myLinkCmdSingle
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/telnetlib.py", line 283, in write
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/socket.py", line 228, in meth
error: (32, 'Broken pipe')
_______
Norm
