Plugin for reporting current Mac CPU usage?
Fri Feb 23, 2018 10:29 am
Professor Falken offline
Does anyone know if there is a plugin that returns the current CPU usage (and, for that matter, other health-of-my-Mac stats) for the machine running Indigo?
I looked around on both the store and the larger list of plugins and didn't see anything with that in the description. But was wondering if maybe I missed it.
Fri Feb 23, 2018 11:01 am
Colorado4Wheeler offline
Re: Plugin for reporting current Mac CPU usage?
I have one but haven't published it yet, I expect to publish it in the next month or so but it'll show CPU usage and Memory usage as well. I really wrote it for my own use but as I've used it more and more I've come to see that I should probably publish it after I clean it up and make it pretty.
Screen Shot 2018-02-23 at 10.02.20 AM.png (116.49 KiB) Viewed 1495 times
Fri Feb 23, 2018 1:01 pm
kmarkley offline
My Mac Apps plugin will report Memory/CPU for the system as well as individual application you define as Indigo devices.
https://www.indigodomo.com/pluginstore/92/
( It doesn't report on other Indigo plugins the way C4W's appears to...)
Fri Feb 23, 2018 2:18 pm
Great, thanks. I'll check it out.
Fri Feb 23, 2018 2:35 pm
Check out I indigo utilities plugin has similar reporting.
