CraigM wrote:Part 1
Is there a way to set KPL buttons 3,4,5,6 LED's to be always OFF?
I'm setting up a keypad and I need the button pushes to be picked up by triggers, but the buttons never to light up.
They are currently in non-toggle mode and only send ON
I believe the only way is to have them always send OFF. You could have the triggers that fire turn them back off I suppose, but that might not have the right user experience for your application.
CraigM wrote:Part 2
LED's for buttons 1 & 2 are being turned on/off by a variable, is there a way to disable the buttons pushes?
Not that I know of - physical presses always work I think. You probably could make triggers that would set them back to their former state (might require some scripting) but again that might not have the right user experience for your application.
