Hi All,
I would like to start a new calibration on a fibaro dimmer 2.
Can someone point me in the right direction for sending this command via the send raw packet data tool?
It's parameter 13 --> set it to 1
Regards
matt (support) wrote:It looks like you included that module with encryption enabled. Since it is a dimmer I highly recommend not using encryption since it: increases the number of commands (by a lot), increases odds of congestion and collisions, and there tend to be more firmware bugs (in the module) hit when using encryption.
I don't know that is related to the problem setting parameter 13 to 1, but it is possible that it is.
To include it without encryption you have to exclude it, then re-include it (without encryption), then resync it. You do not need to create a new Indigo device – just use the existing one.
