Aeon Labs Doorbell Gen5
Wed Nov 15, 2017 4:17 am
rodb offline
I would like to use this device to respond with different sounds to different triggers.
Parameter #2 Set the repetitions for playing doorbell ringtone. Value=1 to 255.
Parameter #6 Select a ringtone to play. Value=1‐100, play the specified ringtone.
Parameter #8 Set the volume of ringtone. Value=0‐10.
Is this ever going to be supported in the GUI? If not, how can I use this device's features with Indigo?
Wed Nov 15, 2017 6:38 am
Re: Aeon Labs Doorbell Gen5
Indigo has had the UI settings for those parameters over a year now (7.0.0). You can access them via an Action by choose the Z-Wave action type Modify Configuration Parameter.
If you aren't seeing them (in that action type or the device settings dialog) then resync the module and copy/paste the Event Log results into a forum reply.
Wed Nov 15, 2017 2:33 pm
rodb offline
Works perfect when you know what you are doing. They were there. I just didn't know where to look. Thanks.
