Change pending
Wed Aug 16, 2017 10:59 pm
MarcoGT offline
Change pending
Hi all,
I modified the settings (poll time) of a Fibaro Door/Window sensor; now, state is "change pending" and I do not get notified when the window is opened/closed.
If a make a change again, nothing happens.
Shall I exclude it and re-include it?
Marco
Wed Aug 16, 2017 11:20 pm
Re: Change pending
Wake the device - its waiting to apply the changes you made but can't until it wakes up.
Usually hourly but you might have changed the wake interval.
There will be a button inside it to force it to wake.
Wed Aug 16, 2017 11:43 pm
MarcoGT offline
Re: Change pending
Yes, I did it.
Originally it was 4h, then I changed it to 1 per day, but the change was not applied. I would have expected that having 4h, after 4h max, the change was applied, but I was wrong.
I will try to wake it up again.
Thu Aug 17, 2017 10:35 am
Re: Change pending
Changing a configuration setting on a sleeping module shouldn't impact how it sends/receives alarm commands (door/window open/close). So I think something else went wrong. If manually waking it doesn't help then try excluding/re-including, and re-syncing. Also make sure it has fresh batteries.
