Re: Battery Status not changing
Posted:
Sat Mar 25, 2017 1:11 pm
by mlew
Hi Matt
below is log for smoke alarm took me couple of attempts to wake device, will do door sensor now.
Z-Wave sent "Landing Smoke Tamper" status request
Z-Wave Debug RCVD requestSensAlarmSensorStatus: 01 0D 00 04 00 2D 07 9C 02 2D 00 FF 00 00 90
Z-Wave Debug . . requestSensAlarmSensorStatus: node 045, endpoint None, cmdClass 9C, alarmType 0, value 255, classSubKey 9C00FF
Z-Wave Debug filtering duplicate command -- old: 9C00FF, 0, FF, new: 9C00FF, 0, FF (0.2824 secs)
Z-Wave Debug SENT requestVarSensorStatus: 01 09 00 13 2D 02 31 04 25 D0 0A
Z-Wave sent "Landing Smoke Temperature" status request
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 2D 06 31 05 01 22 00 D4 1F
Z-Wave Debug . . requestVarSensorStatus: node 045, endpoint None, type 1, raw value 2200...
Z-Wave Debug . . requestVarSensorStatus: 21.2 °C (float: 21.200000)
Z-Wave received "Landing Smoke Temperature" sensor update to 21.2 °C
Z-Wave Debug SENT goToSleep: 01 09 00 13 18 02 84 08 24 D1 86
Z-Wave Debug RCVD packet: 01 07 00 13 D1 00 00 01 3B (hex)
25 Mar 2017, 19:08:56
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 26 06 31 05 04 22 01 80 44
Z-Wave Debug . . requestVarSensorStatus: node 038, endpoint None, type 4, raw value 2201...
Z-Wave Debug . . requestVarSensorStatus: 38.4 W (float: 38.400000)
Z-Wave Debug received "Kitchen Lights" power load to 38.4 W
25 Mar 2017, 19:09:26
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 2B 06 31 05 04 22 00 E1 29
Z-Wave Debug . . requestVarSensorStatus: node 043, endpoint None, type 4, raw value 2200...
Z-Wave Debug . . requestVarSensorStatus: 22.5 W (float: 22.500000)
Z-Wave Debug received "Kitchen Light 2" power load to 22.5 W
Schedule Landing Lights On/Off (delayed action)
Z-Wave Debug SENT setMultiLevelValue: 01 0E 00 13 1C 07 60 0D 01 01 26 01 00 25 D2 44
Z-Wave sent "Landing Light" off
Z-Wave Debug queueing energy request of "028 - Landing Light" (activity detected)
Z-Wave Debug RCVD requestDimmerStatus: 01 09 00 04 00 1C 03 26 03 00 C8
Z-Wave Debug . . requestDimmerStatus: node 028, endpoint None, value 0
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 2D 06 31 05 01 22 00 DC 17
Z-Wave Debug . . requestVarSensorStatus: 22.0 °C (float: 22.000000)
Posted:
Sat Mar 25, 2017 1:13 pm
by mlew
door sensor has much bigger log!
5 Mar 2017, 19:11:26
Z-Wave Debug RCVD requestSensAlarmSensorStatus: 01 0D 00 04 00 10 07 9C 02 10 00 FF 00 00 90
Z-Wave Debug . . requestSensAlarmSensorStatus: node 016, endpoint None, cmdClass 9C, alarmType 0, value 255, classSubKey 9C00FF
Z-Wave received "Back Door Tamper" status update is on
Trigger Back Door Tamper Reset
Z-Wave Debug intiatingSyncUI (timeout in 1500 seconds)
Z-Wave Debug RCVD requestSensAlarmSensorStatus: 01 0D 00 04 00 10 07 9C 02 10 00 00 00 00 6F
Z-Wave Debug . . requestSensAlarmSensorStatus: node 016, endpoint None, cmdClass 9C, alarmType 0, value 0, classSubKey 9C0000
Z-Wave received "Back Door Tamper" status update is off
Z-Wave Syncing - started for "Back Door Sensor"
Z-Wave Debug SENT getNodeNeighbors: 01 06 00 80 10 01 01 69
Z-Wave Debug RCVD getNodeNeighbors: 01 20 01 80 00 00 41 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E
Z-Wave Debug . . getNodeNeighbors: nodeId 016, neighbors: 17, 23, 25
Z-Wave Syncing - retrieved module neighbors list: 17, 23, 25
Z-Wave Syncing - assigning return route to "016 - Back Door Sensor"
Z-Wave Debug SENT assignReturnRoute: 01 05 00 46 10 01 AD
Z-Wave Debug RCVD assignReturnRoute: 01 04 01 46 01 BD
Z-Wave Debug RCVD assignReturnRoute: 01 05 00 46 01 00 BD
Z-Wave Debug . . assignReturnRoute: node 016, success 1
Z-Wave Debug SENT requestNodeInfo: 01 06 00 60 10 24 D5 78
Z-Wave Debug RCVD nodeInfoFrame: 01 15 00 49 84 10 0F 04 20 01 30 9C 85 72 70 86 80 56 84 7A EF 2B 5C
Z-Wave Debug . . nodeInfoFrame: node 016, combined class list: 20v1 80v1 84v1 85v1 86v1 70v1 30v1 72v1 56v1 7Av1 9Cv1
Z-Wave Debug SENT requestManufactureInfo: 01 09 00 13 10 02 72 04 25 D6 72
Z-Wave Debug RCVD requestManufactureInfo: 01 0E 00 04 00 10 08 72 05 01 0F 07 00 10 00 83
Z-Wave Debug . . requestManufactureInfo: node 016, manufacturerId 010F, productId 07001000
Z-Wave Debug . . requestManufactureInfo: Fibaro System, Door/Window Sensor (FGK101)
Z-Wave Syncing - retrieved manufacture and model names: Fibaro System - 010F, Door/Window Sensor (FGK101) - 07001000
Z-Wave Debug SENT requestVersInfoGen: 01 09 00 13 10 02 86 11 25 D7 92
Z-Wave Debug RCVD requestVersInfoGen: 01 0D 00 04 00 10 07 86 12 03 03 43 02 05 31
Z-Wave Debug . . requestVersInfoGen: node 016, protoVers 3.67, appVers 2.05
Z-Wave Syncing - retrieved protocol version 3.67, app version 2.05
Z-Wave Debug SENT requestVersInfoCmdClass: 01 0A 00 13 10 03 86 13 84 25 D8 19
Z-Wave Debug RCVD requestVersInfoCmdClass: 01 0A 00 04 00 10 04 86 14 84 01 F2
Z-Wave Debug . . requestVersInfoCmdClass: node 016, class command 84 using version 1
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Binary Sensor : Binary Sensor (routing) (04 : 20 : 01, base 30)
Z-Wave Syncing - retrieved command classes: 20v1 80v1 84v1 85v1 86v1 70v1 30v1 72v1 56v1 7Av1 9Cv1
Z-Wave Syncing - retrieved encrypt commands: - none -
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, waking
Z-Wave Debug SENT requestWakeInterval: 01 09 00 13 10 02 84 05 25 D9 8A
Z-Wave Debug RCVD requestWakeInterval: 01 0C 00 04 00 10 06 84 06 00 0E 10 01 7C
Z-Wave Debug . . requestWakeInterval: node 016, interval 60 minutes, wakeTarget 001
Z-Wave Syncing - retrieved wake interval of 60 minutes
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 2B 06 31 05 04 22 00 E2 2A
Z-Wave Debug . . requestVarSensorStatus: 22.6 W (float: 22.600000)
Z-Wave Debug received "Kitchen Light 2" power load to 22.6 W
Z-Wave Debug SENT setWakeInterval: 01 0D 00 13 10 06 84 04 00 0E 10 01 25 DA 97
Z-Wave Syncing - device "016 - Back Door Sensor" wake interval changed to 60 minutes
Z-Wave Debug SENT requestAssociationGroupCount: 01 09 00 13 10 02 85 05 25 DB 89
Z-Wave Debug RCVD requestAssociationGroupCount: 01 09 00 04 00 10 03 85 06 03 61
Z-Wave Debug . . requestAssociationGroupCount: node 016, group count: 3
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 10 03 85 02 01 25 DC 8A
Z-Wave Debug RCVD requestAssociations: 01 0C 00 04 00 10 06 85 03 01 05 00 01 62
Z-Wave Debug . . requestAssociations: node 016, group: 1, num associations: 1, max associations: 5, replies left: 0
Z-Wave Debug . . requestAssociations: node 016, group: 1, associations: [1]
Z-Wave Syncing - retrieved group 1 associations: [1]
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 10 03 85 02 02 25 DD 88
Z-Wave Debug RCVD requestAssociations: 01 0C 00 04 00 10 06 85 03 02 05 00 01 61
Z-Wave Debug . . requestAssociations: node 016, group: 2, num associations: 1, max associations: 5, replies left: 0
Z-Wave Debug . . requestAssociations: node 016, group: 2, associations: [1]
Z-Wave Syncing - retrieved group 2 associations: [1]
Z-Wave Debug SENT requestAssociations: 01 0A 00 13 10 03 85 02 03 25 DE 8A
Z-Wave Debug RCVD requestAssociations: 01 0C 00 04 00 10 06 85 03 03 01 00 01 64
Z-Wave Debug . . requestAssociations: node 016, group: 3, num associations: 1, max associations: 1, replies left: 0
Z-Wave Debug . . requestAssociations: node 016, group: 3, associations: [1]
Z-Wave Syncing - retrieved group 3 associations: [1]
Z-Wave Syncing - group 1 association to interface already exists (skipping)
Z-Wave Syncing - group 2 association to interface already exists (skipping)
Z-Wave Syncing - group 3 association to interface already exists (skipping)
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 10 03 70 05 05 25 DF 7F
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 10 05 70 06 05 01 FF 68
Z-Wave Debug . . requestConfigVal: node 016, parm index 5, value 255 (size 1)
Z-Wave Syncing - retrieved parameter 5 "Group 1 command type" is 255
Z-Wave Debug . . requestConfigVal: node 016, combined config vals: 5:255
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 10 03 70 05 09 25 E0 4C
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 10 05 70 06 09 01 00 9B
Z-Wave Debug . . requestConfigVal: node 016, parm index 9, value 0 (size 1)
Z-Wave Syncing - retrieved parameter 9 "Disable off commands" is false
Z-Wave Debug . . requestConfigVal: node 016, combined config vals: 9:0 5:255
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 10 03 70 05 03 25 E1 47
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 10 05 70 06 03 01 00 91
Z-Wave Debug . . requestConfigVal: node 016, parm index 3, value 0 (size 1)
Z-Wave Syncing - retrieved parameter 3 "Switch type" is 0 "Normally Closed"
Z-Wave Debug . . requestConfigVal: node 016, combined config vals: 9:0 3:0 5:255
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 10 03 70 05 01 25 E2 46
Z-Wave Debug RCVD requestConfigVal: 01 0D 00 04 00 10 07 70 06 01 02 00 00 05 91
Z-Wave Debug . . requestConfigVal: node 016, parm index 1, value 0 (size 2)
Z-Wave Syncing - retrieved parameter 1 "Delayed off" is 0 seconds
Z-Wave Debug . . requestConfigVal: node 016, combined config vals: 9:0 3:0 5:255 1:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 10 03 70 05 0C 25 E3 4A
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 10 05 70 06 0C 01 08 96
Z-Wave Debug . . requestConfigVal: node 016, parm index 12, value 8 (size 1)
Z-Wave Syncing - retrieved parameter 12 "Temperature sensitivity" is 8
Z-Wave Debug . . requestConfigVal: node 016, combined config vals: 9:0 3:0 12:8 5:255 1:0
Z-Wave Debug SENT requestConfigVal: 01 0A 00 13 10 03 70 05 02 25 E4 43
Z-Wave Debug RCVD requestConfigVal: 01 0B 00 04 00 10 05 70 06 02 01 01 91
Z-Wave Debug . . requestConfigVal: node 016, parm index 2, value 1 (size 1)
Z-Wave Syncing - retrieved parameter 2 "Enable LED flash on change" is true
Z-Wave Debug . . requestConfigVal: node 016, combined config vals: 1:0 2:1 3:0 5:255 9:0 12:8
Z-Wave Debug SENT requestBatteryLevel: 01 09 00 13 10 02 80 02 25 E5 B5
Z-Wave Debug RCVD requestBatteryLevel: 18 (RETRANSMIT REQUEST)
Z-Wave Debug SENT requestBatteryLevel: 01 09 00 13 10 02 80 02 25 E5 B5 (re-sent because retransmit request)
Z-Wave Debug . . requestBatteryLevel: requeuing 1 unsolicited packets
Z-Wave Debug RCVD requestSensAlarmSensorStatus: 01 0D 00 04 10 10 07 9C 02 10 00 FF 00 00 80
Z-Wave Debug filtering duplicate command -- old: 9C00FF, 0, FF, new: 9C00FF, 0, FF (0.1229 secs)
Z-Wave Debug filtering duplicate command -- old: 9C00FF, 0, FF, new: 9C00FF, 0, FF (0.0205 secs)
Z-Wave Debug filtering duplicate command -- old: 9C00FF, 0, FF, new: 9C00FF, 0, FF (0.0397 secs)
Z-Wave Debug filtering duplicate command -- old: 9C00FF, 0, FF, new: 9C00FF, 0, FF (0.0371 secs)
Z-Wave Debug filtering duplicate command -- old: 9C00FF, 0, FF, new: 9C00FF, 0, FF (0.1325 secs)
Z-Wave Debug filtering duplicate command -- old: 9C00FF, 0, FF, new: 9C00FF, 0, FF (0.1329 secs)
Z-Wave Debug filtering duplicate command -- old: 9C00FF, 0, FF, new: 9C00FF, 0, FF (0.0710 secs)
Z-Wave Debug filtering duplicate command -- old: 9C00FF, 0, FF, new: 9C00FF, 0, FF (0.1863 secs)
Z-Wave Debug timeout waiting for reply from module (retrying)
Z-Wave Debug SENT requestBatteryLevel: 01 09 00 13 10 02 80 02 25 E6 B6
Z-Wave Debug RCVD requestBatteryLevel: 01 09 00 04 00 10 03 80 03 FF 9D
Z-Wave Debug . . requestBatteryLevel: node 016, level 255
Z-Wave Syncing - retrieved battery level of 0%
Z-Wave Syncing - complete
Z-Wave Debug terminatingSyncUI
25 Mar 2017, 19:12:26
Z-Wave Debug RCVD requestVarSensorStatus: 01 0C 00 04 00 2D 06 31 05 01 22 00 D2 19
Z-Wave Debug . . requestVarSensorStatus: 21.0 °C (float: 21.000000)
Z-Wave received "Landing Smoke Temperature" sensor update to 21.0 °C
25 Mar 2017, 19:12:57
Schedule Back Door Tamper Reset (delayed action)
Z-Wave updated "Back Door Tamper" to off
Posted:
Fri Oct 13, 2017 8:54 am
by InsteonDiego
Hello -
In lieu of starting a new topic, this issue seems related to an issue I am seeing with the Zooz 4-in-1 sensor not updating their battery level once depleted and changed. This issue only occurs on sensors with encryption enabled, those with encryption disabled function normally. I graph the battery levels of the motion sensors and can clearly see the battery level deplete to zero over time. Those with encryption stay at zero after the battery is replaced, those unencrypted will update their battery level after a couple of hours have passed. The only solution I have found is to use the Define & Sync process several times and once in a while I get lucky and the battery status updates.
The issue would be more clear if battery updates were never sent, however I only see this once new batteries are placed. Is it possible the update is being lost during decryption (or not being sent at all)?
Here is info on the device:
Indigo Z-Wave Version: 2.0.68
Node ID: 20
Model: Zooz Multi Sensor (ZSE40)
Model ID: 20212101
Manufacturer: Zooz
Manufacturer ID: 027A
Protocol Version: 4.05
Application Version: 16.09
Model Definition Version: 1
Library Type: 3
Class Name: Notification Sensor
Class Hierarchy: 04 : 07 : 01
Command Class Base: 00
Command Versions: 20v1 80v1 84v2 85v1 86v1 71v1 70v1 31v7 72v1 73v1 98v1 59v1 5Av1 7Av1 5Ev1
Encryption Status: Enabled for Commands 80 84 85 86 71 70 31 72 73 59 5A 7A
Features: routing, battery, beaming, security, waking
Neighbors: 6, 14, 15, 16
Associations: 1:[1]
Config Values: 1:1 2:1 3:1 4:5 5:2 6:2 7:1
Here is an update received from the device that may be battery related, with value 255 showing that the battery is still dead (but not entirely sure!)
RCVD nonceFetch: node 020
Z-Wave Debug SENT nonceReport: 01 11 00 13 14 0A 98 80 65 09 E1 9D BB 2D 2C 71 25 7F 7A
Z-Wave Debug RCVD encryptedPacket: 00 71 05 07 FF 00 FF 07 08 00 00 (decrypted)
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 10 00 04 00 14 0A 71 05 07 FF 00 FF 07 08 00 00 FF
Z-Wave Debug . . requestAlarmSensorStatus: node 020, endpoint None, cmdClass 71, type 7, value 255, classSubKey 7107FF
Z-Wave Debug . . requestAlarmSensorStatus: typeExt 7, valueExt 8, classSubKeyExt 7107FF0708
Thanks in advance for any steps towards resolution!
