Irrigation system / controller for Hunter
Mon Mar 06, 2017 3:43 pm
RageDoctor offline
Dear Folks,
I am currently planning a irrigation system for my garden. I need up to 14 valves and I would like to control them with Indigo instead of using the Hunter control. Any thoughts on devices or gateways? How can I control the 14 Hunter valves (PGV 100 mmB)?
Best regards
Marcus
Every beginning is hard...
Software: Indigo 6.1.4
Controller: Z-Stick Gen 5
Devices: Fibaro Wall Plug, Motion Sensor and Door/Window Sensor, Aeon Labs MultiSensor 6, more to come...
Mon Mar 06, 2017 10:51 pm
Re: Irrigation system / controller for Hunter
You can use an rpi with the pibeacon plugin. Add a 16 relay board that should be all you need.
Mon Mar 20, 2017 4:22 pm
rvarela offline
You could also look at the OpenSprinkler solution. Works very well for me
Mon Mar 20, 2017 11:44 pm
freshwuzhere offline
Realise this is a little old but I use a bluespray which goes to 64 zones and does pretty much what all the other "smart watering systems" do. It has Ethernet connection - which I much prefer and It's not very expensive compared to some controllers and it has a solid restful interface / supported API. I've have a super basic plugin working (I only want to log whether it watered or not to add to my daily report) but it could easily be expanded to a full indigo watering system. Oh and best of all - their customer service is really good.
Thu Apr 06, 2017 11:32 am
RageDoctor offline
Wow, there are plenty of controllers available (in the US) for sprinklers. Thanks for sharing this.
However, as I do like playing around,I was finally able to built a SPS controlfor 24V and 230V collectors.
Tue Apr 11, 2017 8:25 pm
ar26pt2 offline
I kept my hunter: it was already installed and works great, just wanted a little more logic to prevent over-watering: http://forums.indigodomo.com/viewtopic.php?f=133&t=18242
Wed Apr 12, 2017 3:36 pm
jens offline
What about Hydrawise its have a open API
And hunter bought the company,
//jens
