Howto round Temperature Sensor values
Fri Jan 27, 2017 7:47 am
Umtauscher offline
I am searching for a way to round temperature sensor values. I find it useless to get a temperature value of 23.45 °C from a sensor when I know 0.1 °C is the best accuracy I could get.
So is there a way to round e.g. temperature values when they are sent by the sensor?
BTW I only use z-wave so maybe a trigger on incoming z-wave command would do the trick?
I just don't know how to do it. Any ideas?
Thanks in advance
WIlhelm
Fri Jan 27, 2017 9:25 am
RAID5 offline
Re: Howto round Temperature Sensor values
Hi
This might not be the best solution but it works
I created a trigger that triggers on temperature change on the sensor device
In the trigger I have three actions
1. Copy the sensor value to a variable (Insert Device State into Variable(Variable Actions))
Variable "CPV1_Indoor_Temp_Interim"
2. Execute a applescript that rounds of the temperature value
set a to value of variable "CPV1_Indoor_Temp_Interim"
set the value of variable "CPV1_Indoor_Temp_Interim" to round (a)
end tell
3.Depending on how you use the value this might not be necessary
I do this last step because I show this variable on a Control panel that is shown 27/4 in my kitchen and I don't want it to flicker every time it recalculates the vale
This step copy (Set variable to variable(variable action)) the variable to a new variable that i show on my Control panel page
RAID5 "A happy Swede addicted to automation"
Fri Jan 27, 2017 11:19 am
Couldn't you use the Adapters plugin for this?
Fri Jan 27, 2017 1:59 pm
Umtauscher offline
Sorry Adapters plugin? What is that?
I have more than 20 sensors, so I don't want to have redundant code for every sensor.
I was hoping for a more generic solution.
Cheers
Wilhelm
Fri Jan 27, 2017 3:22 pm
Hi Wilhelm, it's a plugin that allows you to create Indigo devices to convert values for many different purposes, including changing the precision of a value or converting a value (say, from Fahrenheit to Celcius). It's incredibly cool and extremely useful. For example, I wanted all my control page temperature values to be of the same precision and followed by ºF, so I create adapters only for those values that don't meet my preferred style. I have a special folder that I use when I create one so that they're all in one place.
http://forums.indigodomo.com/viewtopic.php?f=134&t=15793&hilit=adapters+plugin
Sat Jan 28, 2017 7:29 am
Umtauscher offline
Thanks for the hint and the explanation.
