Device custom states in to variables
Sun Jul 03, 2016 10:58 am
Indy_Larry offline
I am hoping to hear of a better way people are handling this. Right now I am having to go through and create a variable folder for the device I'm wanting to get information on. Then within that folder, I'm creating each variable name for the custom state that I'm wanting to know about or use. Then I'm creating a trigger so the variable will get populated with the device information.
Under actions > Variable Actions > Insert Device State into Variable > Select device and edit action setting
Lets take Daves Weather Underground plugin (its a great plugin Dave), it probably has more than 20 custom states that you can create a variables for. Are guys going in and manually creating variables for all of the custom states you want/need and then creating a trigger with multiple actions to populate all of those variables?
As of now I have one trigger for each device with multiple Actions to fill those variable fields with the device information.
Larry
Larry
Insteon, Z Wave, Hue, Sonos
Sun Jul 03, 2016 11:01 am
ckeyes888 offline
Re: Device custom states in to variables
I myself typically trigger directly from the device state change.
Rarely have a need for a separate variable with it's info.
Carl
Sun Jul 03, 2016 11:03 am
Carl is correct – is there a particular reason you need the device states pushed into variable values? In most places that one uses a variable value they could also use a device state.
Sun Jul 03, 2016 11:39 am
johnpolasek offline
The only time I had to do it was the highly specialized instance where a very short duration signal (in my case the Dakota Driveway sensor and PiBeacon door open/close states) were being used by a "poll once per minute"plugin (IndigoPlotD) Even using the "Maximum" option on the door open histogram plot, it missed almost all of the 1 second on/off on the driveway sensor and a good deal of the 5 to 10 second open/close on the doors till I created a variable that echoed the state with an instantaneous open/on trigger and a 1 minute delay on the close/off trigger.
Sun Jul 03, 2016 2:28 pm
Thanks Larry. You should be able to get the information you need directly from each plugin device.
Screen Shot 2016-07-03 at 3.24.54 PM.png (62.58 KiB) Viewed 2246 times
What are you trying to accomplish, exactly?
Dave
Mon Jul 04, 2016 7:37 am
you could increase the sampling rate for indigoplotD down to 1 every 4 seconds.. down from 1 every 1 minute. BUT this should only be done when your MAC can handle it.
Trying does not hurt though.
or another way o catch fast changing devices/states: everytime the state changes increment a variable. You them know exactly how often a door was opened/ closed. Then plot "DELTA" in indigoplotD.
in config:
Screen Shot 2016-07-04 at 08.32.28.png (96.87 KiB) Viewed 2153 times
Tue Jul 05, 2016 4:01 pm
Indy_Larry offline
Thanks everyone, for your replies. Matt, Carl, Dave you are correct and it seems I can do this in most if not all of things I'm working on now. I sometime I just over complicate things, and this is why I reached out.
As always thanks everyone.
Larry
Tue Jul 05, 2016 4:11 pm
Been there! Glad to help.
