I have an action group command which issues all lights off - Insteon and X10. It used to work fine, but recently I get lots of errors suggesting devices not in database (see below) such as ""Powder Room Sconce" off; failed (PowerLinc not in module's database -- try the Define and Sync process in the device dialog)". But the system knew to try these devices. Further, when I go to the device itself, Indigo can sense its on/off status and can turn it on/off without issue. When I run the all off again, same devices report not in database. Not sure what is going on, INDIGO certainly knows the devices and can operate them with direct commands - it is just the ALL OFF that fails. Thoughts?
- Code: Select all
Oct 23, 2015, 12:06:54 PM
Schedule All Lights Off
Action Group All Lights Off
Sent X10 all lights off (house code P)
Sent INSTEON "Lower Water Fall" off
Sent INSTEON "office lights" off
Error "Boys Bathroom Fan" off; failed (PowerLinc not in module's database -- try the Define and Sync process in the device dialog)
Error "Garage inside" off; failed (PowerLinc not in module's database -- try the Define and Sync process in the device dialog)
Sent INSTEON "Powder Room Overhead" off
Sent INSTEON "TV Room Sconce" off
Error "Powder Room Sconce" off; failed (PowerLinc not in module's database -- try the Define and Sync process in the device dialog)
Sent INSTEON "Kitchen undercounter" off
Sent INSTEON "Patio Fan Switch" off
Error "Pool House Overhead Light" off; failed (PowerLinc not in module's database -- try the Define and Sync process in the device dialog)
Error "Patio Fan - Light" off; failed (PowerLinc not in module's database -- try the Define and Sync process in the device dialog)
Sent INSTEON "Rear Patio Lights Floor Two" off
Sent INSTEON "m bathroom shower" off
Sent INSTEON "master bedroom closet lights" off
Error "Laundry Room" off; failed (PowerLinc not in module's database -- try the Define and Sync process in the device dialog)
Sent INSTEON "Boys Bathroom Shower" off
Error "Boys Bathroom Sconce" off; failed (PowerLinc not in module's database -- try the Define and Sync process in the device dialog)
Sent INSTEON "Pool House Fan Switch" off
Error "pool house fan - Light" off; failed (PowerLinc not in module's database -- try the Define and Sync process in the device dialog)
Sent INSTEON "Pool House outside" off
Sent INSTEON "Upper Hill Lights1" off
Sent INSTEON "Rear Patio Lights #2" off
Sent INSTEON "Rear Patio Lights #1 linked" off
Sent INSTEON "basement Lower Stairs Pair2" off
Sent INSTEON "basement Lower Stairs Pair1" off
Sent INSTEON "Basement Playroom Back pair" off
Sent INSTEON "Rear Patio Lights #3" off
Sent INSTEON "basement top pair" off
Sent INSTEON "guest bedroom back" off
Sent INSTEON "guest bedroom front" off
Sent INSTEON "guest bathroom" off
Sent INSTEON "guest bedroom hall / a" off
Sent INSTEON "living room hall / b" off
Sent INSTEON "lining room hall / a" off
Sent INSTEON "living room sconces / b" off
Sent INSTEON "living room sconce / A" off
Sent INSTEON "living room R overheads" off
Sent INSTEON "Living Room C Overheads" off
Sent INSTEON "Living Room L overheads" off
Sent INSTEON "entry sconce-2" off
Sent INSTEON "entry sconce" off
Sent INSTEON "hall chandelier" off
Sent INSTEON "childrens hall-2" off
Sent INSTEON "childrens hall" off
Sent INSTEON "childrens bedroom #2" off
Sent INSTEON "children bedroom" off
Sent INSTEON "stairs sconces" off
Sent INSTEON "upper passageway sconces" off
Sent INSTEON "m bathroom overhead" off
Sent INSTEON "m bathroom sconces" off
Sent INSTEON "master bedroom lights" off
Sent INSTEON "Kitchen Overhead #2" off
Sent INSTEON "Kitchen Overhead #1" off
Sent INSTEON "kitchen hanging" off
Sent INSTEON "Dining Room Chandelier" off
Sent INSTEON "Dining Room Sconces" off
Sent INSTEON "Basement Playroom Closet" off
Sent INSTEON "Basement Under Great Room" off
Error "Basement Front Closet" off; failed (PowerLinc not in module's database -- try the Define and Sync process in the device dialog)
Sent INSTEON "TV Room Lights" off
Sent INSTEON "Rear Patio Lights #4" off
Sent INSTEON "Garage Lights" off
Sent INSTEON "Rear Patio Lights #2 linked" off
Sent INSTEON "Rear Patio Lights #1" off
Sent INSTEON "Back Porch Lights Main" off
Sent INSTEON "Front Porch Lights Main" off
Sent INSTEON "Waterfall Lights" off
Sent INSTEON "Back wall Lights2" off
Sent INSTEON "Back wall Lights1" off
Sent INSTEON "Front Wall Lights2" off
Sent INSTEON "Front Wall Lights1" off
Sent INSTEON "Driveway Lights" off
Sent INSTEON "Basement Playroom Back " off
Sent INSTEON "Basement Bathroom" off
Sent INSTEON "Basement Playroom" off
Sent INSTEON "Basement Exercise Room Back" off
Sent INSTEON "Basement Exercise Room2" off
Sent INSTEON "Basement Exercise Room1" off
Sent INSTEON "Basement Lower Stairs" off
Sent INSTEON "Basement Top" off
Sent INSTEON "Upper Water Fall (Main)" on
Sent INSTEON "Lower Water Fall" on
