gregjsmith wrote:Still, if deleted and re added the device I shouldn't have got the errors.
The last line of the log you posted above is very clear.
Either the device is not awake or there is no route within 6 hops (6 powered devices) of the Zstick.
If you're new to Zwave, have a read of this thread where my response seems to be appreciated by beginners:
viewtopic.php?f=152&t=14297To get the device setup again in Indigo, regardless of whether it was working for a day or so, you need to go and wake it up as you hit the define&sync button, exactly as you set it up in the first place.
If that still isn't working, check your other powered (not battery) Zwave devices between the Zstick and the sensor - are any of them unplugged? Have you moved (or removed) any of them?
Peter
