LED Landscape Lighting Causing Interference?
Tue Nov 18, 2014 7:22 pm
ticotice offline
Anyone having trouble with 12V AC landscape lighting (using LED bulbs) causing interference with wireless Insteon modules? I've been getting massive delays/no responses by my Insteon motion sensors when my landscape lights turn on at sunset. After swapping the halogens for LEDs, the motion sensors see the motion (flashing red LED) but their attempts to turn on /off my security flood lights are "blocked" or massively delayed.
Any ideas? :?:
Wed Nov 19, 2014 5:48 am
Seeker offline
Re: LED Landscape Lighting Causing Interference?
I have noticed LED indoor bulbs causing general interference with over the air TV reception. I used an attic-mounted antenna. A couple of channels are blocky sometimes when lights are on. turn off leds and it is clear. I have about 10 led bulbs, but even turning 2-4 on will cause noticeable tv interference. I'm not sure what frequencies OTA hdtv uses, but there's definitely something there in my environment.
I don't use insteon but use zwave. i have not noticed any significant zwave issues.
Wed Nov 19, 2014 6:10 am
I just replaced my halogen landscape lights with these: http://www.amazon.com/gp/product/B00CFA4VDU/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1#. I use Z-Wave exclusively and have seen no interference. I have three banks of lights, each on its own power supply and each controlled by a Z-Wave outdoor module.
Dave
Wed Nov 19, 2014 9:54 am
Have you tried putting the landscape lights on a FilterLinc?
All my outside low voltage lighting using the old bulbs, but I've never had any trouble with my INSTEON gear with them.
Wed Nov 19, 2014 11:44 am
ticotice offline
Jay,
Haven't tried a FilterLinc on the landscape transformer yet. Also noticed that my garage door opener does not respond properly to wireless remote commands when the landscape lights are on. Will put a FilterLinc on the transformer tonight and see what happens!
BTW, which Z-wave motion sensor do you recommend?
JTice
Wed Nov 19, 2014 4:53 pm
ticotice offline
Jay,
Tried the FilterLinc on my 2 landscape transformers and it made no difference. Did a little surfing to find this website: http://www.ledbenchmark.com/faq/LED-int ... ssues.html. Apparently the LEDs themselves emit enough RFI that it blocks my garage door opener remote from my car. This RFI must also be reducing the responsiveness of my Insteon motion sensors. Interesting that the largest RFI comes from an MR16 LED bulb. I have several of those as uprights on trees. Got more research to do on this issue!
Jeff
Wed Nov 19, 2014 5:15 pm
Interesting...
And somewhat annoying...
Mon Nov 24, 2014 9:30 pm
ticotice offline
Interesting...
Yes, absolutely annoying. When I turn off my landscape lighting and activate either my Insteon motion sensor or my garage door opener remote control, everything works perfectly. Quite obviously the landscape 12 volt AC LEDs are creating just enough RFI to prevent the RF signals from either the motion sensor or the garage door opener from getting through to their respective actuators. Not sure how to handle this, but I may have to swap to Z-wave Motion sensors and have them turn off the landscape lights temporarily so the garage door opener will work. Crazy scenario, but may it be the only way to get this to work properly! :?
Jeff
Tue Nov 25, 2014 3:27 am
colinpartridge offline
The ledbenchmark article implies that some led units produce more rf than others, I would be inclined to try a different brand of led. It could also be just one rogue unit. One suggestion I saw was to put ferrite chokes on the power lines close to the light.
Colin
Fri Nov 28, 2014 9:33 am
ticotice offline
Colin
Good idea to try ferrite chokes. I'll grab a few of those and see how it works. I've swapped out a few of my LED back to halogens attempting to isolate the most offending bulbs. However, it appears that the cumulative RFI from the 12 LEDs lining my driveway and near the front of my garage is causing the problem. Since it only occurs when the landscape lighting is on, I'm adjusting my habits to it. (Meaning, I have get out of my car at night to open the garage door!) :lol:
Sat Jan 21, 2017 1:27 pm
For my landscape lighting, I currently have three zones--that is, three "Malibu" transformers plugged into three GE outdoor Z-Wave modules. The setup works just fine, but it looks terrible. Big transformer and module hanging on the wall, with cords and cables dangling. Blech.
What I would like to do this spring is 12v distribution--install a 12v transformer centrally (at the breaker panel), and control it with one appliance module, smart switch, or some such Z-Wave device and then run 12v wire to the three zones. The load is small at about 18w, but I would like to add a few spots as well. I expect that a 60w transformer would be more than enough. Would make for a much simpler and cleaner install--and I'm guessing somewhat more efficient.
Has anyone done this? Are there any US electrical code considerations?
ps: relatedly, I've switched to these Philips LEDs: and they work great. They're somewhat expensive at $6 but I feel they're the cheaper alternative because I'm not replacing 1 or 2 lights per month like I was with a cheaper alternative. They only draw 1.2w. Love them.
