I have had a warming mattress pad that has a mechanical on/off switch. In other words it stays on when power is removed from the pad, so an on/off module works perfectly. Well the pad finally gave out. I can only find heating pads that have, what I call, an electronic switch. When power is removed from the pad the unit defaults to off, so the on/off module will not work.
I believe I know the answer to this, but is there an alternative way to get around this issue. Seems more and more items are going this route. I am sure I am not the first to have this issue. Please send help or my SO will be on me about it, and not in a good way.
