2014-06-16 22:18:26.876 Z-Wave Error send "Espresso Machine Power" status request failed
2014-06-16 22:18:26.877 Z-Wave received "Espresso Machine Power" status update is off
Here is the device info...
- Code: Select all
Z-Wave Indigo Device "Espresso Machine Power" Z-Wave Properties:
Indigo Z-Wave Version: 1.0.232
Node ID: 6
Model: Appliance Module (AN157)
Model ID: 00040001
Manufacturer: Everspring
Manufacturer ID: 0060
Protocol Version: 2.64
Application Version: 1.02
Model Definition Version: 0
Library Type: 4
Class Hierarchy: 03 : 10 : 01
Command Class Base: 25
Command Versions: 20v1 25v1 86v1 27v1 72v1 73v1 75v1
Features: beaming
Neighbors: 1, 29
Associations: - none -
Config Values: - none -
- Code: Select all
Z-Wave Syncing - started for device "Espresso Machine Power"
Z-Wave Syncing - retrieved module neighbors list: 1, 29
Z-Wave Syncing - requesting neighbor list update of "006 - Espresso Machine Power"
Z-Wave Syncing - neighbor list update complete (no change)
Z-Wave Syncing - retrieved manufacture and model names: Everspring - 0060, Appliance Module (AN157) - 00040001
Z-Wave Syncing - retrieved protocol version 2.64, app version 1.02
Z-Wave Syncing - retrieved class hierarchy: Slave : Relay Switch : Relay Power Switch (03 : 10 : 01, base 25)
Z-Wave Syncing - retrieved command classes: 20v1 25v1 86v1 27v1 72v1 73v1 75v1
Z-Wave Syncing - complete
Z-Wave sent "Espresso Machine Power" status request
