Effect/danger of driving a 12v device with 24v
Sat Apr 21, 2018 1:28 am
noel1983 offline
Hi all,
Can anyone guide me as to potential effects or danger of powering a 12vac doorbell with 24vac? It’s a mechanical chime doorbell which I think is a motor that spins briefly that then makes a traditional bell move and ring.
Suspect there’s some risk to over powering the bell motor but is there any fire risk or anything like that?
Noel
Sat Apr 21, 2018 1:35 am
siclark offline
Re: Effect/danger of driving a 12v device with 24v
Don't most doorbell transformers have adjustable output?
Sat Apr 21, 2018 1:37 am
noel1983 offline
I’ve just had to fit a new 24v psu to Drive my hikvision doorbell (mentioned in another post), but my old psu was 12v so my assumption is the bell/motor is too.
Can’t figure out how to get inside the bell without damaging it so can’t see the motor itself
Sun Apr 22, 2018 6:13 pm
rehafer offline
Maybe something like this to be safe.
https://www.amazon.com/gp/aw/d/B076R44F ... ref=plSrch
Sun Apr 22, 2018 8:19 pm
https://www.amazon.com/gp/aw/d/B076R44F ... ref=plSr ... won't work with AC
assuming you need 0.5 Amps then add a resistor 24 ohm 6 watt in series (or 6 times 1 watt 150 Ohm in parallel makes 24 Ohms 6 watts (*) )
That should do the trick .. its a waste if energy but should be ok.
(*) like these: https://www.amazon.com/s/ref=nb_sb_noss ... hm+1+watts
Sun Apr 22, 2018 9:13 pm
rehafer offline
I didn’t know doorbell power was AC. You’ve likely saved me grief on a future project, thanks.
Sun Apr 22, 2018 9:28 pm
at least this one seems to be "12vac doorbell with 24vac"
Sun Apr 22, 2018 9:33 pm
rehafer offline
Yep, I missed it
