Greetings,
I am try to create a Virtual Device. I select NEW/TYPE and Virtual Device is greyed out. I select INTERFACES and Virtual Device has no menu (no arrow).
Can you assist please?
Kind regards,
Z
Oct 27, 2023 at 11:39:39 AM
Starting Indigo Server version 2022.2.2 on macOS Version 12.7 (Build 21G816)
Loading database "/Users/administrator/Documents/Office.indiDb"
Waiting for client to connect
Retrieved unchanged location for sunset/sunrise calculation
Indigo Cocoa client connected
Waiting for client to sync
Finding disabled plugins
Found disabled plugin "MQTT Broker 2022.1.0" using API v3.0
Found disabled plugin "Hubitat Bridge 2022.0.9" using API v3.0
Found disabled interface "INSTEON Commands 2022.2.1" using API v3.0
Loading internal plugins
Loading interface "Z-Wave 2022.2.1" using API v3.0
Starting interface "Z-Wave 2022.2.1" (pid 43009)
Loading plugin "Web Server 2022.2.0" using API v3.0
Starting plugin "Web Server 2022.2.0" (pid 43010)
Loading plugin "Action Collection 2022.2.0" using API v3.0
Starting plugin "Action Collection 2022.2.0" (pid 43011)
Loading plugin "Vera Bridge 2.2.0" using API v2.0
Starting plugin "Vera Bridge 2.2.0" (pid 43012)
Started plugin "Action Collection 2022.2.0"
Started interface "Z-Wave 2022.2.1"
Z-Wave connected to Z-Stick Gen5 (ZW090) interface on /dev/cu.usbmodem14701 (firmware 1.00, SDK unknown)
Z-Wave found module included in controller with no matching device (missing or disabled): 003 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 004 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 005 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 006 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 007 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 008 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 009 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 010 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 011 - Basic Repeater Slave
Z-Wave found module included in controller with no matching device (missing or disabled): 012 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 013 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 015 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 016 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 017 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 020 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 022 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 024 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 025 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 027 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 029 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 030 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 032 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 037 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 044 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 050 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 051 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 055 - General Thermostat (v2)
Z-Wave found module included in controller with no matching device (missing or disabled): 057 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 059 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 063 - General Thermostat (v2)
Z-Wave found module included in controller with no matching device (missing or disabled): 068 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 069 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 070 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 073 - Keypad Door Lock
Z-Wave found module included in controller with no matching device (missing or disabled): 074 - Keypad Door Lock
Z-Wave found module included in controller with no matching device (missing or disabled): 075 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 076 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 077 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 078 - Keypad Door Lock
Z-Wave found module included in controller with no matching device (missing or disabled): 079 - Relay Power Switch
Started plugin "Vera Bridge 2.2.0"
Z-Wave found module included in controller with no matching device (missing or disabled): 084 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 087 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 088 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 091 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 093 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 094 - Keypad Door Lock
Z-Wave found module included in controller with no matching device (missing or disabled): 100 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 101 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 105 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 113 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 116 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 126 - Secure Barrier Add-On
Started plugin "Web Server 2022.2.0"
Web Server starting internal Web server on http://localhost:8176
Waiting for internal plugins to initialize
Bonjour registered "Indigo - Office"
Reflector starting reflector connection to https://tes.indigodomo.net
Loading external plugins
Loading plugin "Cynical Behaviors 3.1.0" using API v3.0.0
Starting plugin "Cynical Behaviors 3.1.0" (pid 43031)
Loading plugin "Z-Wave Interpreter 2022.0.0" using API v3.0
Starting plugin "Z-Wave Interpreter 2022.0.0" (pid 43032)
Loading plugin "DSC Alarm 2022.0.6" using API v3.0
Starting plugin "DSC Alarm 2022.0.6" (pid 43033)
Loading plugin "Virtual Garage Door 1.2.1" using API v3.0
Starting plugin "Virtual Garage Door 1.2.1" (pid 43034)
Loading plugin "HomeKitLink Siri 0.6.5" using API v3.2
Starting plugin "HomeKitLink Siri 0.6.5" (pid 43035)
Started plugin "Virtual Garage Door 1.2.1"
Z-Wave Interpreter
============================================= Initialising Z-Wave Interpreter Plugin =============================================
Plugin Name: Z-Wave Interpreter
Plugin Version: 2022.0.0
Plugin ID: com.autologplugin.indigoplugin.zwaveinterpreter
Indigo Version: 2022.2.2
Indigo License: ActiveSubscription
Indigo API Version: 3.2
Architecture: x86_64
Python Version: 3.10.2 (v3.10.2:a58ebcc701, Jan 13 2022, 14:50:16) [Clang 13.0.0 (clang-1300.0.29.30)]
Mac OS Version: 12.7
Z-Wave Interpreter Indigo Event Log set to 'Debugging'
Z-Wave Interpreter Plugin Log set to 'No Z-Wave Logging'
Started plugin "Z-Wave Interpreter 2022.0.0"
Cynical Behaviors API version 3.2
Cynical Behaviors Python version 3.10.2.final.0
Started plugin "DSC Alarm 2022.0.6"
Started plugin "Cynical Behaviors 3.1.0"
HomeKitLink Siri
HomeKitLink Siri ================================================ Initializing New Plugin Session =================================================
HomeKitLink Siri Plugin name: HomeKitLink Siri
HomeKitLink Siri Plugin version: 0.6.5
HomeKitLink Siri Plugin ID: com.GlennNZ.indigoplugin.HomeKitLink-Siri
HomeKitLink Siri Indigo version: 2022.2.2
HomeKitLink Siri Python version: 3.10.2 (v3.10.2:a58ebcc701, Jan 13 2022, 14:50:16) [Clang 13.0.0 (clang-1300.0.29.30)]
HomeKitLink Siri Python Directory: /Library/Frameworks/Python.framework/Versions/3.10
HomeKitLink Siri
HomeKitLink Siri ================================================== End Initializing New Plugin ==================================================
Started plugin "HomeKitLink Siri 0.6.5"
HomeKitLink Siri Finding devices to publish to HomeKit Given Startup...
Waiting for external plugins to initialize
HomeKitLink Siri Starting accessory HomeKitLink Bridge 285967 on address 10.0.1.15, port 51826.
Starting triggers and schedules
Oct 27, 2023 at 11:40:07 AM
HomeKitLink Siri A total of 87 devices are currently selected to be published to HomeKit
HomeKitLink Siri 87 Home Kit Accessories are now Started.
Users browsing this forum: No registered users and 17 guests
