cannot install Lutron Leap plugin
Fri Dec 01, 2023 9:24 pm
tsoulen offline
I upgraded to Indigo 2023.1. I am unable to install the Lutron Leap plugin. I reinstalled Indigo and tried a second time. My log says this:
Dec 1, 2023 at 10:18:39 PM
Installing and enabling plugin Lutron Leap v2022.1.2
Error ReloadPlugin() caught exception: FileIOError -- rename/move of file or folder failed -- check file/folder permissions
Reloading plugin "Web Server 2023.1.0" using API v3.3
Stopping plugin "Web Server 2023.1.0" (pid 2356)
Stopped plugin "Web Server 2023.1.0"
Starting plugin "Web Server 2023.1.0" (pid 2469)
Started plugin "Web Server 2023.1.0"
Web Server starting internal Web server on http://localhost:8176
Bonjour registered "Indigo - NewestMy House (v7.4.1) (v2022.1.2) copy (v2022.2.2)"
Error failed to create reflector connection: public/private keys not found
Fri Dec 01, 2023 9:49 pm
Re: cannot install Lutron Leap plugin
Have you tried installing any other plugins? (Even if you don't plan on using them)
Sat Dec 02, 2023 8:44 am
tsoulen offline
Just tried to install the AppleTV plugin. It does show up in the Plugins in Indigo, but with a red dot. Tired unsuccessfully to reload.
Dec 2, 2023 at 9:40:59 AM
Installing and enabling plugin appleTV Plugin v1.2.0
Loading plugin "appleTV Plugin 1.2.0" using API v3.1
Starting plugin "appleTV Plugin 1.2.0" (pid 1085)
Stopping plugin "Web Server 2023.1.0" (pid 790)
appleTV Plugin Error Error in plugin execution InitializeMain:
File "plugin.py", line 163, in <module>
type: name 'pyatv' is not defined
Stopping plugin "appleTV Plugin 1.2.0" (pid 1085)
Stopped plugin "appleTV Plugin 1.2.0"
Starting plugin "Web Server 2023.1.0" (pid 1090)
Dec 2, 2023 at 9:41:46 AM
Reloading plugin "appleTV Plugin 1.2.0" using API v3.1
Starting plugin "appleTV Plugin 1.2.0" (pid 1164)
Stopping plugin "appleTV Plugin 1.2.0" (pid 1164)
Sat Dec 02, 2023 9:18 am
You picked one that needs an external library installed. But the plugin installed properly, so that's good.
Have you rebooted the Indigo system since all this started? It's possible the OS has a lock on a file that's not visible in the plugin folder anymore.
After the reboot I would re-download the LEAP plugin to make sure you have a good copy.
Sat Dec 02, 2023 9:21 am
This line has me a little concerned:
Looks your your database has been renamed by multiple upgrades, with a copy in there somewhere. I'd make sure you're actually using the correct database. And if it was me I'd clean up that database name so it's obvious it's current. If you do that, make sure you do it when the Indigo server is NOT running.
Sat Dec 02, 2023 10:01 am
tsoulen offline
OMG, I'm back in business! I deleted Lutron Leap, quit Indigo, restarted the computer for good measure, restarted, opened Indigo, downloaded and installed Leap. Got a debugging message I hadn't seen before. It works! Thank you so much for your extraordinary patience with me. I really appreciate it.
Dec 2, 2023 at 10:53:01 AM
Loading plugin "Lutron Leap 2022.1.2" using API v3.1
Starting plugin "Lutron Leap 2022.1.2" (pid 988)
Stopping plugin "Web Server 2023.1.0" (pid 876)
Starting plugin "Web Server 2023.1.0" (pid 993)
Started plugin "Lutron Leap 2022.1.2"
Lutron Leap Debug startup
Lutron Leap Debug run_async_thread starting
Lutron Leap Debug async_main starting
Lutron Leap Debug startup complete
