2023.1 - Server starts every time I start the client
Wed Oct 11, 2023 10:59 pm
MKuchnic offline
I just upgraded to 2023.1 and I also upgraded to MacOS Sonoma. When I start the Mac, the indigo server loads and runs without issue, my computer is also set to auto logon. However when I start the client (on the server computer) the server starts again. This happens every time I quit and then start the client. As a work around I leave the client running.
Was this a change with 2023.1, or did I miss a setting to prevent this. When I l run the client on another Mac everything works as expected (it just connects but doesn’t start the server).
Thu Oct 12, 2023 2:57 am
Re: 2023.1 - Server starts every time I start the client
Tue Oct 17, 2023 9:56 am
Fixed in Indigo 2023.1.1, available now.
Fri Nov 17, 2023 12:11 pm
MKuchnic offline
My apologies for the delay in responding. You are correct and everything is fixed!
Turns out when I initially discovered the issue I turned off automatically starting the server to validate it wasn't impacted by that setting. I managed to forget to reset it to automatically start after I installed the fix, and when I tested it, I restarted to validate it installed properly and had a clean start.
My apologies for not doing a better job testing/validating.
Mark
P.S. I love the new API since I can use it from shortcuts on my phone to trigger all kinds if actions
Fri Nov 17, 2023 2:35 pm
Thanks, we thought it would be a really great addition with lots of use-cases.
