Best work around after upgrading to 12.3.1
Wed Apr 06, 2022 9:24 am
pgershon offline
NOTE: Indigo 2022.1 has solved the compatibility issue with macOS Monterey 12.3+.
I missed the announcement (I am now subscribed to that page). What is my best bet now?
1) I have never used Time Machine to restore my system files, although I make hourly or more frequent updates. Should I try to do a full restore (if that exists)? In theory, I have a backup from yesterday, assuming Time Machine works properly. I could try to restore back to before the update. I have only used Time Machine in the past to restore individual data files.
2) I have a Macbook Pro 2016 model that is not doing much. I could set it up with Indigo and let it run Indigo Server for my network until an updated version of Indigo is released. If likely to be only a few weeks?
Wed Apr 06, 2022 3:59 pm
Re: Best work around after upgrading to 12.3.1
I'd do option #2 if I were you. Fill out the contact form and ask us to deactivate you license so that when you move the install to the other Mac you can activate it there (this is step #1 in those directions since you won't be able to do it yourself).
Wed Apr 06, 2022 4:34 pm
pgershon offline
Thanks Jay. Yeah I did all that and I have everything working except the Sonos Plugin. For some reason, it will not load the plugin without error on when the MacBookPro is the Indigo Server. I set the listening IP to the IP of the MacBookPro but I get an error message in the log. I am comparing the log from today to the start up a month ago and I see where things break down, but I cannot diagnose the cause.
This is the current log:
Sonos Loaded Sonos Favorites... [12]
Sonos Loaded Playlists... [1]
Sonos Loaded RadioTime Favorite Stations... [2]
Sonos: Initialized: SXM_Bolt_On V1.2.A
Sonos Serving HTTP Streamer on 192.168.1.71 [0.0.0.0], port 8888
Sonos_Dev 'NoneType' object has no attribute 'get' <== This was the error that was returned from the init_chan_array / test_the_water / sxm_tester function call
Sonos <== This is the username from the init_chan_array function that was used to login to SiriusXM
Sonos [Wed Apr 6 18:20:00 2022] Processed plugin preferences.
Sonos SoCo Reactor Ignition...
This was last month when it worked (server ID for iMac was 192.168.1.100):
2022-03-18 19:07:22.369 Application Started plugin "Sonos 1.1.17b"
2022-03-18 19:07:22.688 Sonos Using Reference ZonePlayer IP: 192.168.1.194
2022-03-18 19:07:22.776 Sonos Loaded Sonos Favorites... [12]
2022-03-18 19:07:22.792 Sonos Loaded Playlists... [1]
2022-03-18 19:07:22.856 Sonos Loaded RadioTime Favorite Stations... [2]
2022-03-18 19:07:22.875 Sonos: Initialized: SXM_Bolt_On V1.2.A
2022-03-18 19:07:22.940 Sonos Serving HTTP Streamer on 192.168.1.100 [0.0.0.0], port 8888
2022-03-18 19:07:23.437 Sonos_Dev 'NoneType' object has no attribute 'get' <== This was the error that was returned from the init_chan_array / test_the_water / sxm_tester function call
2022-03-18 19:07:23.439 Sonos <== This is the username from the init_chan_array function that was used to login to SiriusXM
2022-03-18 19:07:23.439 Sonos [Fri Mar 18 19:07:23 2022] Processed plugin preferences.
2022-03-18 19:07:23.457 Sonos Loaded Apple Voices.. [48]
2022-03-18 19:07:23.457 Sonos SSDP Listener Started...
2022-03-18 19:07:23.537 Sonos Adding ZonePlayer: 192.168.1.194, RINCON_949F3E25590A01400, Sonos Player
2022-03-18 19:07:23.546 Sonos SoCo Reactor Ignition...
Not getting:
Wed Apr 06, 2022 5:29 pm
Yep, I just wanted to document it in case someone else has the same question.
Wed Apr 06, 2022 8:02 pm
pgershon offline
I figured out the issue. There is supposed to be a folder "Perceptive Automation\images\Sonos" that was missing. I tried to copy it over from the old server but had to change the permissions of the Perceptive Automation folder to get it in. Once the folder was there, the error messages went away and everything works as it did before,
