Not connecting to Caseta Gateway since upgrade
Mon Dec 21, 2020 4:26 pm
tsoulen offline
Since I upgraded to Indigo 7.4 and upgraded by Lutron Caseta plugin, I have lost control of my Caseta devices. I used the command to create devices from Caseta SmartBridge Pro, and my gateway did appear in my device list. Here is what the log says:
Dec 21, 2020, 5:06:40 PM
Lutron RRA2/Caséta Error Lutron IP Gateway: Unable to connect to Lutron gateway. Timed out.
Lutron RRA2/Caséta Warning Lutron IP Gateway: Error sending IP command, resetting connection: 'NoneType' object has no attribute 'write'
The first screen shot shows what I see under DEVICES.
The second screen shot shows the settings for my gateway.
Screen Shot 2020-12-21 at 5.24.11 PM.png (49.79 KiB) Viewed 1018 times
Screen Shot 2020-12-21 at 5.21.28 PM.png (30.05 KiB) Viewed 1018 times
Mon Dec 21, 2020 4:57 pm
Re: Not connecting to Caseta Gateway since upgrade
Delete the gateway device and re-create it. I have no idea how you got the rfc2217:// string in the address field, but that's broken.
You'll probably need to edit each of your (Lutron) plugin devices and select the new gateway device.
And this should be moved to the Lutron plugin forum.
Wed Dec 23, 2020 12:54 pm
tsoulen offline
I deleted and added the gateway back in. I'm still having problems.
Screen Shot 2020-12-23 at 1.51.31 PM.png (125.33 KiB) Viewed 930 times
Screen Shot 2020-12-23 at 1.50.32 PM.png (34.58 KiB) Viewed 930 times
Screen Shot 2020-12-23 at 1.50.11 PM.png (86.93 KiB) Viewed 930 times
Wed Dec 23, 2020 4:31 pm
Is the Indigo device # for the new gateway 288529729? Or is that the old gateway device number? You need to edit all the actual devices to specify the new gateway.
OTOH, looks like you found a bug in the code. Rename your gateway to pure ASCII. You've got a unicode non-breaking space in the name.
https://github.com/FlyingDiver/Indigo-r ... /issues/49
Also, please do not post screen shots of the Indigo log. Just cut and paste the text into the post. Makes it much easier for me to copy lines out of the log.
